Panhard bar interference - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 07-11-2013, 09:52 AM
Originally Posted by 27Tall T View Post
Have it on a hoist and extremely difficult to really see the clearances as you are looking up at the problem instead of directly at it. Can only see a bit at a time with a mirror as the mufflers, driveshaft etc. are in the way. My last photo shot was when I jammed the camera at one end and kept shooting until I had a decent picture portraying my latest problem (couldn't see the view finder). I think the only solution is to recut the floor (cut it to clear the banjo housing). I find that TCI puts out a good product, but they need to do more suspension engineering. Another instance was when I had to cut the front fender supports to clear the independent suspension!! Why they didn't widen the stance to clear the brackets is beyond me.
Because the control arms would have to be too short to keep the tires from hitting the fenders. And by the way on that floor, I am thinking you take it all the way off from the side supports to the rear body panel, to over the rear end, the whole thing, replace it with one that gives you more clearance. I am thinking this would very possibly be the easiest way to handle this. Without a bunch more photos it's kinda hard but take a look at this idea and make your choice.
  #32 (permalink)
Old 07-11-2013, 11:47 AM
techinspector1's Avatar
Wiki Edits: 326
Can you see how contradictory this statement is. If they made a good product, there would have been no reason for this thread in the first place. If a company makes junk and people buy it, they will continue to make junk.
  #33 (permalink)
Old 07-11-2013, 02:36 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
TCI builds good quality parts from my experience. I used some of their parts with no problems whatsoever when I built my Model T RPU and Model A Tudor. The builder is the one that has to make sure that the combination of parts he selects works for a given application. We're building hot rods here, not a bolt together factory five kit car. If things don't work right on the initial test drive then modifications are needed, and that's ok. That's what this forum is all about, right? Hell that's why GM, Ford, etc. build "test mules", to work out the bugs.
And when it comes to panhard bars, the length you need has a lot to do with the suspension type you have and what, realistically, the articulation of the rear axle will be. I have a '65 C10 also and when I modified the rear suspension I wrote a tech thread on my research of how much difference a longer panhard bar would make... check it out here: http://talk.classicparts.com/showthread.php?t=14368/
I've made a living as an engineer for over 30 years. So I too like well engineered components. But simpler is almost always better. Watt's links are cool, but they are way overcomplicated, compared to a panhard bar, for a street driven vehicle. That's why they don't put them on factory built vehicles, they simply aren't needed.
  #34 (permalink)
Old 07-11-2013, 02:51 PM
Wiki Edits: 326
Originally Posted by lakeroadster View Post
TCI builds good quality parts from my experience. But the installer is the one that has to make sure that his combination of parts works for a given application. We're building hot rods here, not a kit car. If things don't work right on the initial test drive then modifications are needed. That's what this forum is all about, right?
With all due respect to you sir, building good quality parts does not include fashioning a Panhard bar that is half as long as it needs to be according to good engineering practices. Again, if you guys continue to buy their junk, they will continue to produce junk.
  #35 (permalink)
Old 07-11-2013, 03:16 PM
And when it comes to panhard bars, the length you need has a lot to do with the suspension type you have and what, realistically, the articulation of the rear axle will be. I have a '65 C10 also and when I modified the rear suspension I wrote a tech thread on my research of how much difference a longer panhard bar would make... check it out here: Track Bars, The Short and The Long Of It... - Classic Parts Talk
I have to tell you, your diagrams prove the point! Now, I am not here to argue the NEED for the longer bar, I understand that with a lot of cars there is so little travel it isn't going to make a big difference. However as Bugs Bunny would say "It wouldn't hoyt". But getting back to your link that was posted. In the first one it shows a short panhard bar with the suspension fully bottomed out and the rear end has moved 11/16 of an inch! That is darn near 3/4", which is a TON when you are talking about some of these cars. A fenderless model A with tires tucked up next to the body, that is a TON. And exhaust to shocks and on and on, that is a lot for a rear end to move.
Then on the diagrams with the long panhard bar it shows to moves a half an inch, first off, yes that is less than the short bar, but look at the steep angle of the bar! That is exactly what we are talking about. If that bars mounting points were at the same height it wouldn't move the rear end over anywhere near that 1/2".
You have apples and oranges if we are to be looking at what is the difference in lateral movement of the rear end with the short or long Panhard bar.
  #36 (permalink)
Old 07-11-2013, 03:18 PM
Have you ever seen a Chevrolet C-10 truck built from 1963 thru 1972? All the 2 wheel drive models utilized panhard bars that attached to the frame on one side, and to the center differential housing on the other end. Worked great on the millions of trucks that GM sold. I wonder, were those junk according to the "Tech Inspector Good Engineering Practices Manual"?
Guys I agree that watts links are better than a long panhard bar. And that a long panhard bar is better than a short panhard bar. But what works for a given application, and what is most cost effective is the "real world engineering" approach.
27Tall T is looking for the simple fix for his situation. Talking about watts links and longer track bars is interesting, but not needed in his case. All he needs is suspension to floorboard clearance. Keep it simple.
  #37 (permalink)
Old 07-11-2013, 03:34 PM
Now that's the truth!
  #38 (permalink)
Old 07-11-2013, 03:47 PM
Wiki Edits: 326
So, now you have to get snotty and make it personal???? Have a nice day.
  #39 (permalink)
Old 07-11-2013, 04:11 PM
sedanbob's Avatar
Tech, You were the one in this thread with all the attitude. My suspension was designed by Pete & Jakes, and uses a panhard bar from the frame rail to the far side of the pinion support - similar to the TCI design - too short and lousy engineering by your statements. I checked the side to side movement throughout my suspension travel (which is very short like a lot of '30s rods). My bar is level at ride height. The side to side movement is about 3/16" as the suspension cycles from center to the top, and from center to the bottom. A panhard bar works quite well in this application.
  #40 (permalink)
Old 07-11-2013, 07:12 PM
Nothing "snotty" at all. Answer the question, you opened the door, walk through it...
  #41 (permalink)
Old 07-11-2013, 08:43 PM
life is a temporary assignment
  #42 (permalink)
Old 07-11-2013, 09:27 PM
Okay, I did a mock up and with one pivot point of the panhard bar 3/4 " from the sedan floor (attached to the frame) and the other 2 3/4" from the floor ( making a 2" difference) and increasing the length of the bar 3" (now 22 1/4"), I have an angle of 3 degrees downward slope. I know that the pivot points have to be in line, but nothing is perfect in this world, and neither is my suspension. However, I think this would give me the clearance I need. Any comments on this?
  #43 (permalink)
Old 07-12-2013, 01:56 AM
327NUT's Avatar
I've stayed out of this since it got "technically" involved, I read now that my chassis is "junk" because my panard bar is not long enough.....and I am perpetuating this unsound engineering because I bought it. Well so be it, funny thing though besides TCI, Pete & Jakes, Heidts, Roy Brizzio, SoCal Speed Shop, Mr. Roadster, Chassis Engineering and I'm sure a few more all use the shorter panard bar from the port side to the pinion support. Just look at thier web sites......so these guys sell junk also, Hmmm and a custom built turn key '32 roadster from Brizio starts at 185K.
The reason for the junk engineered bar you ask?? Well there's several, it's probably a lot cheaper to make, there's not a lot of room under an old Ford when you add in 4 bars or split wishbones, shocks, exhaust pipes etc. and the main reason is....it's just not needed. The above company's have thousands of their chassis and turn key hot rods out and about and never once have I heard an owner complain that their panard bar was too short.
I totally agree with the comments by "lakeroadster" and "sedanbob" and yes 27T as I'm sure you know or are finding out these are not bolt together kit cars. If something doesn't fit you have to modify or dare I say re-engineer it for you application.
In regards to your front fender braces, TCI as with other chassis builders have to build a chassis that will work with most of their customers cars. It's not bad or shoddy engineering it's just the way it is, I had to modify my fender braces also but it was no big deal, still have to weld in a backing plate. The headlight bar acts as a support so the strength really isn't compromised that much, some full fendered cars don't even use fender braces. Anyway I'm done for now, too bad this post had to take this turn......Dave
ID:	75592   Click image for larger version
  #44 (permalink)
Old 07-12-2013, 06:15 AM
.. but look at the steep angle of the bar! That is exactly what we are talking about. If that bars mounting points were at the same height it wouldn't move the rear end over anywhere near that 1/2".
Brian,
I agree in theory, however the angle of the long panhard bar shown in the analysis I listed above Track Bars, The Short and The Long Of It... - Classic Parts Talk reflects the CPP "kit" that folks are buying for the 63 through 72 suspensions. The kit bar bolts to the stock frame location and then CPP supplies a panhard bar mount that bolts to the u-bolts at the trailing arm to axle location. Is it ideal, no. Is it the kit folks are using, yes. Does it work, yes. The point of the analysis was to show a stock panhard bar vs. the CPP kit that folks are being told is a "must have" for lowered trucks, which simply is not true.
Here is a photo of the "kit" (not my truck). Photo lifted off the internet.
CPP Kit
  #45 (permalink)
Old 07-12-2013, 08:29 AM
Hey 327...... what you did for the front braces is exactly what I had to do as well. You would think that they would have addressed this issue before selling a product that you have to modify. It's like buying a Ferrari and then deciding you want to make it look like a '57 Chev. Why not buy the right thing without going through the hassle of modifying (which incidentally can be a lot of fun, but at the same time frustrating)?? I suppose its like buying jockey briefs....one size fits all!
panhard bar. elcaminoman69 Suspension - Brakes - Steering 10 11-24-2013 07:26 AM
wish bone, panhard bar, track bar BigBlockT Suspension - Brakes - Steering 6 02-11-2010 10:25 AM
4 bar & panhard blackbart Suspension - Brakes - Steering 41 11-24-2009 07:33 PM
panhard bar uncertainty crackfiller Hotrodding Basics 1 04-03-2007 04:06 PM
Panhard bar revision 5window Suspension - Brakes - Steering 2 11-06-2003 04:31 AM
