Panhard bar, leaf springs and Caltracs?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2013, 08:16 PM
Hey everyone,
I would like to know your thoughts on this...
I have a 58 Chevy PU, Volare front end, GM 12 bolt with Posi and Cal-Trac's Leaf springs with steel bushings. Rear tires are 275/60-15 Nitto Drag Radials at 25psi
Around corners or during transitions the rear end seems to wobble quite a bit, This could be due to sidewall flex or needing a Panhard bar? Its really a straight line truck and have no desire to turn it into a road race deal. Just curious what makes it necessary to need a panhard bar?
Old 06-18-2013, 09:57 PM
Last journal entry: New Rev wheels and BFG KDW II tires
I would say it's the rear tires that are doing it unless something else is really out of wack. Panhard bars were meant for leaf spring suspensions. A watts link could be used on a leaf spring suspension for better control but is really overkill on a street car.
Are you using the factory leaf packs or their twin mono springs?
I've heard that the cal-tracs are a nice option versus the old style traction bars. A cheap trick for getting stock springs to hook is clamping the pack in several places in front of the axle. This worked like a champ running 8" slicks on my 55 Chevy.
The Following User Says Thank You to 64SS327 For This Useful Post:
xxllmm4 (06-19-2013)
Old 06-18-2013, 10:01 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Generally you will not need the panhard with leaf springs..You can check the spring shackles and attachments for any play as under hard cornering there might be some movement that shows up under stress..Other wise it may be sidewall flex..Could be the way the truck is set up you are running what we call a loose setup..
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
Old 06-18-2013, 11:09 PM
life is a temporary assignment
If you have leaf springs, You shouldn't need a panhard bar,, I would say it's your tires sidewall giving in a turn...
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
Old 06-19-2013, 12:09 AM
Thanks for the info everyone, hearing the term Trac bar or Pan-hard bar 20 times during a NASCAR race has me thinking LOL
I'm actually more used to front wheel and all wheel drive imports, so its not really an issue. My other truck, a 77 chevy PU with a stock 350 dosent really need a bar
Old 06-19-2013, 02:23 AM
Banned
your problem = drag radial. soft sidewall
panhard bar. elcaminoman69 Suspension - Brakes - Steering 10 11-24-2013 08:26 AM
leaf springs or 4 bar suspension? Is a 4 bar worth the expense? Hemi-Meadowbrook Suspension - Brakes - Steering 7 03-09-2011 08:18 AM
wish bone, panhard bar, track bar BigBlockT Suspension - Brakes - Steering 6 02-11-2010 11:25 AM
Panhard bar with leaf spring suspension AntnyL Suspension - Brakes - Steering 9 12-21-2007 09:37 AM
Panhard bar revision 5window Suspension - Brakes - Steering 2 11-06-2003 05:31 AM
