Pantera - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-20-2010, 01:05 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by F-BIRD'88
Start with a simple diagnostic cylinder compression test.
What cam did you attempt to run in this motor?.
Brand, part number, grind number.
If you mixed up the old lifters when reinstalling the old cam or if the old cam or lifters had any amount of wear, its not going to work.
The cam lobes and lifter faces will self destruct in minutes.
Its very easy to got the cam installed phasing all wrong on a 70's era ford V8.
There were various different cam/crank timing sprockets all giving different cam timing/phasing on these smog era motors.
Easy to get things messed up with replacement parts. May need to degree the cam to verify actual valve timing.
I forgot to ask you about this Eddie, But as mentioned above did you put the old lifters back where they came out at, Did you mark the location and keep them in order when you removed them or did you just put them back in? In no particular order. You have to keep them in order and put them back in exactly where they came out at. The old lifters already have a wear pattern to the old cam. And as F-Bird stated if you don't install the old ones back where they came from you will wipe the lobes real quick .
Cole
  #17 (permalink)
Old 09-21-2010, 06:45 AM
Pantera
F-BIRD
What you said, is EXACTLY WHAT i HAVE DONE!! I mixed up the old lifters when reinstalling the old CAM. And I am sure they self destruct!!! thank you guys for finding the problem! I have to import AGAIN new parts and go through the jassel of customs and paper work. Last time it took 2 months!
To answer your question.
Q - WHAT CAM I HAVE IN THE ENGINE NOW
A - The old original cam that came in the car. (it's ruin now!!)
CAM Specs from the book.
ENGINE 351-C... LOBE LIFT (intake) = 0.278 (exhaust)=0.283 VALVE LIFT(intake)=0.481 (exhaust)=0.490 CAMSHAFT(end play)=0.001 0.006 (wear limit)=0.009 LOBE LIFT Maximum allowable lobe lift loss=0.005
Q - BRAND...? PART NUMBER...? GRIND NUMBER...?
Could you please suggest a set of new parts I should buy? So they will be compatible with each other? Please.
F-BIRD, You talk of things that haven't cross my mind! (because I don't know!) Quote: THERE WERE VARIOUS DIFFERENT CAM/CRANK TIMING SPROCKETS ALL GIVING DIFFERENT CAM TIMING/PHASING ON THESE SMOG ERA MOTORS. (No idea of what you're talking about!!!)
I would like to up grade the CAM just a little, as long it wont go over 1200 RPM and hold a good idling. The distributor gear fits a CAM for a 351-C I don't know if it's important, but the motor has an Edelbrock intake manifold and a 650cfm Holley. Thanks a lot. Eddie
JMO: You had no reason to imagine that any body in their wright mind, could mix indiscriminately all the lifters! Luckily F-BIRD did!
  #18 (permalink)
Old 09-21-2010, 03:35 PM
eloc431962's Avatar
Wiki Edits: 37
[QUOTE=PANTERA]F-BIRD
What he is talking about Eddie is they make timing sets for 351C that has either 1 location on the crank sprocket or it can come with multiple key-way
locations, This way you can advance or retard the timing when it is installed.
then you tweak it out at the distributer.
Cole
  #19 (permalink)
Old 09-21-2010, 11:12 PM
Pantera
F-BIRD
I am out of luck!.. After reading your kind explanation of how the engine in my car works And what I should or shouln't do in order to get things going the correct way! It brings me to two realizations> First: How grateful I am with a person like you, with your incredible amount of knowledge, which will take it's time to try to help some body thousands of miles a way!
Second: After reading various times your explanations. It brings to my mind that famous Greek philosopher, SOCRATES. when with a glass of "CICUTA" on his hand, and before committing suicide, he said. THE ONLY THING I KNOW... IS THAT, I DON'T KNOW ANY THING!
People like you and COLE, is what it makes the world go around!
Thanks a lot!!
Eddie.
PS. In the book dose not say any thing about the kind of camshaft the car came with. And if the number is in the CAM, it is still in the car, and if is not too much trouble for you; I could send you as soon as I get it out. About the camshaft that screwed every thing up, I will look for the invoice it should be there. Thanks again!
  #20 (permalink)
Old 09-25-2010, 12:50 PM
Pantera
I think the best way to take care of my problem, is just getting a new engine. I have almost 2 years working in this one! And after reading your kind suggestions, I relized I am in a complete different league! It's not just matter of educating myself I don't think I could learn in a couple days what it has taking a long time to people like you to become Masters in the art of Mechanics! I have a BROKER in Miami that could sheep me a new engine. Do you of any reliable shop I could get in touch? I would hate to get one out of Google.
But before getting a new engine, I will like to give one more try to the one is on. Crankshsft, rods pistons etc. (3/4) I think are OK. So I was thinking to get the CAM and LIFTERS F-BIRD suggested. (Elgin #E8065 - hidr Lifters #HL1900) And also get push rods for a 351-C (Hope they send me the wright size.) when changing this 3 things; Does springs and rocker arms, also would have to be change? or could I used the ones are on! Since I have to pull the heads to do all these, I will take the heads to a shop to have the valves checked. I will hate to trough the engine away! What do you think COLE? do you think I will be wasting My time and money??
  #21 (permalink)
Old 09-25-2010, 01:25 PM
SSedan64's Avatar
When you get the Cam out check the Lobes for wear. This & the oil will indicate if metal has circulated through the Engine. Which can ruin Crank & Rod bearings.
The Valve Springs should be replaced IMO, they don't have many miles but, they have sat in one position for a long time & can lose pressure + if the replacement Cam is larger than stock, the Springs wont be able to handle the increased lift & lobe ramp rate.
  #22 (permalink)
Old 09-25-2010, 02:27 PM
eloc431962's Avatar
Wiki Edits: 37
Originally Posted by PANTERA
I will hate to trough the engine away! What do you think ? do you think I will be wasting My time and money??
No i don't think you will be wasting you time or money, I think you are on the right track. But i have to admit without being there and actually seeing what has happened to your engine. As stated check the oil for any metal and the cam lobes as sedan said.
You really do need to take a closer look at things you might have got lucky and nothing else is hurt but you need to check to be sure of it.
I Don't know what your options are where you live Eddie as far as a machinist or machine shop. But yes the heads need to be checked. Don't throw that engine away even if you do get another engine from Miami keep the original engine. But IMHO the entire engine needs to checked for any damage. JMO
Eddie you have any pics of the engine /parts that were hurt ?
Cole
  #23 (permalink)
Old 09-25-2010, 02:59 PM
spinn's Avatar
This is a different situation ,but have swapped many cams. In cam swaps , my lifters remained popped up in their bores, and just slid in the cam. Thus reusing the same lifters in the bores. Prelubed everything with 30 wt, spun the crank and primed it. Never had a lobe wipe or lifter wear.
Is this just lucky?
Do you have 1.6 rockers? .278" lobe lift should be around .420" or something.
If the cam is increased to .480-.490 with a 1.5 , that is alot of lift. The aggressive road car driving dynamic of the pantera will be changed.
  #24 (permalink)
Old 09-26-2010, 02:20 PM
Pantera
This is good news. Thanks COLE. About $600 Sounds much better than over $6.000 For a new engine! Even if it goes wrong! But I'll get the satisfaction to have try to save this engine!
To check the oil?...Definitely will do!! In addition to the cam,lifters and push pods (F-BIRD) suggested.. To buy new springs and rocker arms... Will do!!
If I give to the BOSS of a machine shop, the specs F-BIRD suggested; I doubt he'll know, what he is talking about!
Eddie
edgarbalseca@yahoo.com
pantera 351c and weber's gary5341 Engine 2 02-20-2010 03:02 AM
Introduction UFO-LOW Introduce Yourself 3 01-23-2010 02:51 PM
1971 Pantera 23 Steel T Suspension - Brakes - Steering 10 11-10-2009 08:20 PM
ford351modified chevelle307 Engine 5 09-11-2007 06:25 PM
