Park lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2008, 02:50 PM
Park lights
I have a '66 Mustang Coupe and I have a "strange" issue.
Whenever I apply my brakes the brake lights come on and that is a good thing.
The odd thing is the park lights on the front of the car also light up solid.
Anyone have any ideas why this might be the case?
As I understand it the park lights should only come on when the light switch is pulled out to the first notch or when you are signaling for a turn.
Old 04-16-2008, 03:55 PM
T-bucket23's Avatar
Wiki Edits: 26
I think this is actually normal on the old Mustangs. There are a few Mustang guys on here, maybe they can validate this.
Chet
Old 04-16-2008, 05:07 PM
Wiki Edits: 31
yea.. my '67 Falcon does that also.. I looked at the wiring diagrams a long time ago ( cannot find them now ) IIRC the wires for directionals/ stop lights went to the front also.. which would cause that.. I'm pretty sure it's normal... BTW '67 Falcon uses a Mustang wiring harness.
Old 04-16-2008, 07:19 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
The Mustang IS a Falcon in disguise
Funny, I do not recall my 65 Mustang doing that.
But----I do not remember----do your dash indicators have a right and a left indicator?? Some only have a single indicator.
Perhaps there is a diode on the instrument cluster that has failed.
Just tossing this out---sold the Mustang in the early 90s---so I cannot be positive.
Bryan
Old 04-16-2008, 07:42 PM
Wiki Edits: 31
I know the Mustang/ Falcon are 1 in the same.. makes getting lots of parts easy
Old 04-17-2008, 07:57 AM
"do your dash indicators have a right and a left indicator?? "
I have a left and a right indicator but I had heard some only have a single indicator.
Thanks for the advice.
When I get a chance I am going to make sure (again) that all the lights are working for breaking, turn signaling, etc and if everything is working like it should be (i.e. can pass inspection) then I may decide not to worry so much about the park lights coming on when the brakes are applied.
I need to consider eventually rewiring the entire car but would like to put that one off for a while to address some other issues first....for example my horn doesn't work, need to fix the wiper switch and address a small spot of rust or two.
Old 04-18-2008, 05:32 AM
75gmck25's Avatar
I don't know Mustang wiring well enough to give you a definite answer, but on most cars this type of problem is due to a disconnected ground. If a ground wire is missing from the front lights, or from somewhere in the dash panel, the current might be finding a alternate path to ground through the brake lights.
When Ford first added emergency flashers (about '66?) there was a wierd wiring loop that I discovered as a kid. If I turned on the emergency flashers, stepped on the brake, and I think also turned on one turn signal, I could run the radio without having keys in the ignition. This was very useful when I was stuck in the car waiting for my parents.
Bruce
Having problems with the tail lights... HammerGVette Electrical 3 04-17-2007 01:06 AM
69' GTO no park lights lincoln9 Electrical 3 05-16-2006 03:36 AM
Double Pole Park Lights horvath Electrical 5 08-14-2003 09:05 PM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 05:04 AM
Back Up Lights - how to choose? horvath Body - Exterior 6 03-04-2003 03:20 PM
