Park lock doesn't work on C4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2006, 10:10 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
The Park lock on the transmission isn't working on my 70 Mustang project (C4 Automatic). I guess I'm looking at a transmission removal/repair. You can here it clicking when you roll it around, but it won't lock. Maybe just a linkage adjustment? Has a floor shifter.
Old 09-23-2006, 11:42 PM
Remove the shifter cable linkage and force the trans into park position; see if it holds.
If so, adjust shifter using NEUTRAL as your starting point....
Old 09-24-2006, 03:02 PM
nitro_baller4692's Avatar
floppers forever
those shifters them selves get alot of slop and need to be rebuilt.
Old 09-24-2006, 04:28 PM
Wiki Edits: 31
also Ford trans were noted for having park pawls that didn't hold good. in the 60's it became such an issue ( runaway cars ) that Ford sent out a sticker to all registered Ford owners that was to be placed in the dash center, it said to place trans fully in park and set E brake. my '67 Falcon still has that sticker on the dash.
C4 help, crosley??? k-star Transmission - Rearend 3 07-21-2005 03:50 PM
Front clips and frame swaps --- More work, less value Centerline Suspension - Brakes - Steering 23 05-25-2005 09:42 PM
Social Security. crazy larry Hotrodders' Lounge 48 04-27-2005 11:12 AM
Stuff I work on at work :) esears Hotrodders' Lounge 6 09-29-2003 02:08 PM
Ever work on the impossible? johnsongrass1 Hotrodders' Lounge 16 08-20-2003 02:59 PM
