Parking brake cable parts for light truck rear end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2011, 10:32 AM
question has been asked numerous times in online columns but i need to know what the application is for a gm axle w/ a casting #3896839 (pass. side) and gm 79 (driver side) both- front part of axle assy. had the cover off, did the math-it's a 3.07 ratio but what's the application besides 1964-1982 light truck 1/2 t or 3/4 t. the issue is the presence of this axle as a used replacement in a 55 chevy l.b. 2nd series p/u. I would like to replace the emergency brake cabling system. original has been disconnected and defeated due to the axle changeout and I doubt that a 55 oem or repro replacement is going to function any better. do I just order a 1979 chev light truck long bed emer. brake cabling system for instance or is this going to have to be specially made?
Old 07-04-2011, 11:09 AM
Crosley's Avatar
Wiki Edits: 1659
moving to brake-suspension forum...
Old 07-04-2011, 11:44 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would use the cables what is factory for the rear end that you have and adapt the cables to the brake lever system that you have in the cab..
Sam
Old 07-04-2011, 06:02 PM
ht d rd jack
makes absolute sense assuming the axle is a 79 and the casting # refers to a light truck axle-that seems to be the crux of the id issue-I have not been able to substantiate either piece of data as applying -only hinting. if the pumpkin cover is the clue then I'd call it a gm light truck 12 bolt and move on-thanks for the feedback
Old 07-04-2011, 10:20 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Give the good guys a call over at
controlcablesinc
Thak can match a E-brake combonation
Control Cables Inc.
They matched my 53Chevy to a Ford 9" and They look great and work
1957 Chevy truck parking brake racer819 Suspension - Brakes - Steering 1 07-18-2010 04:11 PM
Sagging parking brake cable rajsid Suspension - Brakes - Steering 9 01-06-2009 11:14 PM
Parking brake cable removal ... TaskForce55 Suspension - Brakes - Steering 4 09-13-2006 10:30 AM
parking brake light 88chevy Electrical 4 06-16-2006 06:55 PM
parking brake cable wally Suspension - Brakes - Steering 1 03-16-2003 05:17 PM
