Parking brake cable removal ... - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2006, 08:12 PM
TaskForce55's Avatar
TaskForce55
Last journal entry: Just checking in
I am removing the rear suspension from my 55 (2nd series) Chevy truck. I can't figure out how to remove the emergency brake cable from the drum brake in the rear. I was able to remove the brake shoes from the drum and from the internal e-brake lever. The only thing I can see is to heat the end fo the cable and remove the 'stopper'. Thoughts?
-tommy
ID:	14641   Click image for larger version
Old 09-05-2006, 08:31 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I think there is a clip type retainer holding the cable in the backing plate. Squeeze that clip and the whole mess should pull back thru the brake drum backing plate I think....
Mechanic
e brake
try using a small hose clamp around the tangs and pull straight out
Old 09-11-2006, 08:33 AM
TaskForce55
Problem solved
Thanks for the advice... after reading your suggestions it made sense - I used a hose clamp. With some pulling it came out. Thanks again!
-Tommy
Old 09-13-2006, 10:30 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
slip a box end wrench over the cable,
usually about a 9/16, tap it on with a hammer to compress the fingers
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
parking brake cable wally Suspension - Brakes - Steering 1 03-16-2003 05:17 PM
