Parking Brake Cables - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2002, 11:46 AM
New Member
Question Parking Brake Cables
is there any kind of trick to getting the parking brake cables out of the return spring arm on the rear disc brakes of my 79 T/A?
Old 12-13-2002, 02:16 PM
dmorris1200's Avatar
doesn't play well with others
Post
Unfortunately I'm not familiar with the set-up on the T/A but I know on some of the rear disc jobs I've done I've had to use a long pry bar to add leverage to move the arm in order to remove the cable.
BUILT FORD TOUGH
Old 12-13-2002, 04:27 PM
4 Jaw Chuck's Avatar
Post
I use a worn out pair of side cutters with the cutting edges blunted to get between the spring, once the jaws are inbetween the spring loops grip the cable end with vise grips and use the side cutters to retract the spring and grip the cable so you can manouver the cable end out. Works with 99% of all cars.
— Han Solo
