Part # for 454, 4spd Flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2009, 04:28 PM
I am putting a 4spd behind my 454. Does anyone have the
GM part# for externally balanced 454, 11" flywheel? Also what
is the purpose of a 14" flywheel? I have a scatter shield I am going
to run and will only except up to 11"
thank you
Old 01-20-2009, 06:28 PM
3963537 External balance,12.75" 153 tooth
3993827 14", 168 tooth
I guess you mean 11" clutch disc? You can get a cover to put an 11" disc on the small flywheel.
Old 01-20-2009, 06:39 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
This is a quick and dirty copy-paste from my GMPP 2008 catalog.
The formatting sucks, but it's all there.
Part Number - Year of Engine - OutsideDiameter - Crank Flange Bolt Pattern - ClutchDiameter - Starter Ring Gear Teeth - Tech Notes
14085720 1965-89 12.75" 3.58" 10.4" 153 Lightweight nodular iron; weighs approximately 15 lbs. For internally balanced engines.
3963537 1979-90 12.75" 3.58" 10.4" 153 Lightweight nodular iron. Counterweighted for externally balanced 454 engines. Use with balancer P/N 3963530.
3991469 1965-69 14" 3.58" 11" 168 Use with internally balanced engines and balancer P/N 3879623.
3993827 1970-90 14" 3.58" 11" 168 Counterweighted for externally balanced Mark IV 454 engines. Use with balancer P/N 3963530.
14096987 1991-up 14" 3.58" 11" 168 Lightweight nodular iron. For external balanced engines.
12582964 1991-up 14" 3.58" 11.5" 168 Used with 572 crate engine
"Dollars are like votes, except that they actually count."
Old 01-21-2009, 09:12 AM
454 Flywheel part#
Thanks for all the help.
My 454 is a Gen4. So I am hearing that all 454
168 tooth are 14" and the clutch assembly is 11"
hence the so called 11" clutch. I am going to be running
a Muncie M20, with a scatter shield, till I twist is then I am
all ready saving for a M22 to keep with the old school theme.
My engine is in the shop right now getting the 496 stroker kit.
I know I should be running a T400, but I like the hands on approach.
I do have a question on shifter. I know it is all preference, but what
is the vote on the best manual shifter for a Muncie that is tight and
quick shifting? My M20 is a wide ratio. Also what is the strongest clutch
set-up on the market? Centerforce III ? Zoom? Borg-Warner?
Thanks
Odd question, but maybe someone can help identify a part. DaSouthWon Suspension - Brakes - Steering 15 10-28-2008 06:17 AM
What flywheel to use with tranny eyecantdrive55 Transmission - Rearend 3 06-10-2007 09:54 PM
Additional 50hp from heads, or 200+lbs off the nose from a LW front suspension clip? NLang General Rodding Tech 29 12-15-2005 02:31 PM
SBC 400 and a saginaw 4spd ? Brobob Transmission - Rearend 3 03-08-2003 04:52 AM
STARTER AND FLYWHEEL DOESN'T MATCH UP mrmonte2323 Engine 8 11-19-2002 06:37 PM
