Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Part time stumble
Old 10-31-2012, 04:07 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
If you have a new fuel filter..... there might be sediment in the tank and at higher rpm it's not totally blocking it, could be water in the tank, could be leaking fuel injectors, could be a leaking fuel line allowing air into the fuel line but not letting gas out...... that actually happened to me once, I figured it out when the ing module crapped out and as I was trouble shooting it I noticed a small amount of fuel on the drive way...... ended up being a loose clamp on the fuel supply line.
