Part time stumble - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2012, 02:32 PM
Part time stumble
I have a 1999 Yukon 130000 plus miles. Run great. I'm getting no codes and checking with a hand held scanner everything seems to be within tolerance. Sometimes after a quick in and out in a store, it will stumble and die after starting. Always restarts and then runs great. Any ideas.
Old 10-30-2012, 03:19 PM
302 Z28's Avatar
Obvious things like fuel filter, plugs air filter and such. Our 2004 Tahoe started something similar but it did not, die just an intermittent stumble while idling. Traced it back to a tank of gas, dropped in a can of fuel injector cleaner and in short order the stumble went away never to return.
Vince
Old 10-30-2012, 07:51 PM
EOD Guy's Avatar
Fuel filter X2
Old 10-31-2012, 07:10 AM
I've checked fuel pressure has new fuel filter. Like I stated not seeing anything on scanner so must be intermitant. Just every now and then will stumble and die after a hot restart.
Old 10-31-2012, 08:14 AM
302 Z28's Avatar
My guess would be it's fuel related. Todays electronics are pretty much bullet proof but I would not totally discount that as the cause.
Vince
Old 10-31-2012, 11:02 AM
Originally Posted by EOD Guy View Post
Fuel filter X2
And yet the truck runs fine at higher RPM, where it would be more sensitive to a plugged fuel filter...
I agree that a bad tank of gas or water in the tank might be the prime candidate. Failing that, I'd pull and inspect the idle air control motor. The pintle and/or seat can become carboned up, resulting in erratic idle.
Old 10-31-2012, 04:07 PM
EOD Guy's Avatar
If you have a new fuel filter..... there might be sediment in the tank and at higher rpm it's not totally blocking it, could be water in the tank, could be leaking fuel injectors, could be a leaking fuel line allowing air into the fuel line but not letting gas out...... that actually happened to me once, I figured it out when the ing module crapped out and as I was trouble shooting it I noticed a small amount of fuel on the drive way...... ended up being a loose clamp on the fuel supply line.
converting transfer case np203 from part time back to full time blade12376 Transmission - Rearend 1 12-05-2011 07:53 PM
BBC stumble on part half throttle diamond mike Engine 2 04-07-2010 07:08 PM
Part-time customizers need advice Dreadlord Garage - Tools 37 04-08-2009 04:58 PM
part time rodder sgt_fixit Introduce Yourself 2 06-13-2007 05:14 PM
Best Part-Time Job nightrain_rod Hotrodders' Lounge 2 08-11-2003 05:22 PM
