Part #for water temp sensor in head
I have gone to a couple of auto part stores but keep geting a temp sensor that fits into the intake manifold. I have a 350 in my 55 chevy truck and want to use the factory temp gauge, I changed heads and did not get the sensor off of the old ones.....So need to know a vehicle make and model or part number for this type of sensor (sending unit), it has a male clip area on the end that the connect slips into.....anyone got any info?
We had a '69 Corvette that used the DS side port on the head for the temp gauge. No telling if the sender would match your gauge. That'd take some research on your part..
Pat |
If you're trying to use the OEM gauge, why not get the correct sensor for that year and model truck motor, and adapt it to your intake or heads? Coolant temp is coolant temp, the correct sensor should send what's needed to the gauge.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
I guessing this is it. Here are TWO to choose from. Now this may not fit into your head. Meaning this is a 3/8" fine thread sender, but your head may be a 1/2" course thread. So you may need an adapter. BTW I looked this up on a 71' C10 with a 350.
BWD - Coolant Temperature Sensor/Sender Part Number: WT203 UPC: 33086040424 http://www.oreillyauto.com/site/c/de...r%21s%21sender ACDelco - Engine Coolant Temperature Sensor Part Number: G1852 UPC: 36666238723 http://www.oreillyauto.com/site/c/de...r%21s%21sender |
What do I win?
| Where to put water temp sensor? | Blazin_Jason | Engine | 10 | 03-03-2008 06:27 AM |
| Water Temp Sensor | longt | Electrical | 1 | 01-03-2008 07:09 PM |
| Water pump, Thermostate, or temp Sensor? | jrm123180 | Engine | 11 | 11-06-2005 01:10 PM |
| water temp sensor location | earthworm | Engine | 13 | 09-07-2005 03:18 PM |
| Water Temp Sensor location | 65chevymike | Engine | 11 | 04-28-2004 12:23 AM |
