Originally Posted by dedub
Thanks Rambo,
That is a nice setup, especially the make it yourself kit. The problem is I have a Cambel Housfeld 13 Gallon 5 HP that only makes 5.1 CFM @ 90 PSI. Im a little short. Specs on the kit need 10-15 cfm air (3 HP minimum - 5 HP is better).
Darrin
Well - you might want to upgrade the compressor first! I doubt you'd be happy with the poor results the small compressor would yeild,
The smaller compressors - is this an oiless? - really pump out a lot of moisture in the lines - a big no-no for parts blaster.
Even with a bigger compressor you need more than a single filter inline - you need a refrigerated line dryer (the best) or some copper lines like this to cool the air and get the moisture out.
Until then - large parts you could farm out and smaller parts
you could buy a tumbler setup -
http://www.harborfreight.com/cpi/cta...emnumber=93252
