Parts list? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2007, 11:08 PM
Parts list?
Lest just say for the sake of argument, that I have no idea what im doing, or that im learning as I go, even as far to say never owned a carburated car befor, and I had a complete engine I wanted to drop into a car that has absolutely nothing. I would think I need the following to make the car run:
Engine w/carb (chevy 350 mild head work and cam)
Distributer/plugs/plug wires
Oil pump/pan
Accessories (alt, water pump, belt)
Wiring for the ignition
Starter
Battery
Battery/starter/alt cables
Radiator w/ lines and fan
Thermostat 190 degree ????????
Fuel lines
4-6lb fuel pressure regulator ????????
60,000 volt coil ??????????
And finally engine and all securely bolted to the car. I'm trying to buy all the parts pre installation so I have to make the midnight runs to Napa less frequent. If there is anything anyone can add, or tell me im and idiot, I would appreciate it.
Jesse
Old 08-30-2007, 11:22 PM
DoubleVision's Avatar
First of all, we need to know the year of the vehicle the engine will be going into and what engine came in that vehicle. And nobody here is going to call you a idiot, we all had to ask at one time just like your doing now, and anytime a question is asked for quest of learning that`s the smart way to do it. The idiot is the one that don`t ask.
Old 08-31-2007, 12:27 AM
Last journal entry: epoxy paint
Hey, from one young learning rodder to another guy wanting to build his car...I think its awesome that your "learning by doing". Hands-on and reading are the only ways that Ive been learning. Come to this forum and research, then ask questions if you dont find what your looking for. Seems like your on the right path to me (for what I know). Good luck, and dont give it up!
-Matt
Old 08-31-2007, 09:45 AM
Jesse,
for "what parts did I forget".....
the Advance Auto and Autozone websites are alot more helpful/quicker/easier....
(NAPA site does give better info on some parts but you have to hunt each part)
on either site, plug in the year/car/motor and click replacement parts, click on a catagory, up pops a broken down list of all parts required.....
ex:
http://www.partsamerica.com/ReplacementParts.aspx
Old 08-31-2007, 09:48 AM
Sorry about that.
1949 Mercury 4 door - completely stripped out engine bay, Chassis and body is all together, no interior.
1985 Chevy 350, 350 turbo trans and Chevy 10 bolt rear end.
Like I said, the engine is fitted, just need to shim up the one side a little, trans crossmember is in place. Once I shim it, I will check the angle of the drive line, 4 - 6 degrees I think I remember reading?
I am going to paint over the chevy orange paint on the block this weekend, drop it back in, and start bolting on parts. Have about half the stuff on my list, the other half I am in process of ordering (hard to take a $3k hit all at once). I just want to be able to start the car, not worried about getting everything finallized yet.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Crankshaft Coalition: Master List of Hotrodding Forums Jon Hotrodders' Lounge 38 01-20-2006 10:47 AM
Pace Performance Parts boss350 Hotrodding Basics 5 05-27-2005 06:43 AM
Hot off the press on the Do-Not-Call... 68Impala Hotrodders' Lounge 0 09-27-2003 12:42 AM
Need help compiling parts list.... m0nk Engine 3 08-31-2003 01:03 PM
