parts swap to 1969 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2010, 01:01 PM
i have a 1969 camaro i am restoring and it needs a heater/ac box. i also have a 1970 montecarlo that has a perfect heat/ac box i was wondering if they will swap? if not can anyone help me with this part as well as a complete wiring kit for the car?
Old 08-30-2010, 01:40 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You can run a free classified (click at the top of the page to get started) for "Parts Wanted".
G'luck.
Old 08-30-2010, 03:51 PM
poncho62's Avatar
Wiki Edits: 5
I dont think a Monte Carlo heater box will fit a Camaro.........Pretty sure a Nova box will though......
Old 08-31-2010, 05:55 AM
malc's Avatar
Living At The Speed Of Life
Have tried an e bay search?
Old 08-31-2010, 07:14 AM
deadbodyman's Avatar
Wiki Edits: 11
Do you mean a heater core???
Old 11-20-2010, 11:58 PM
parts swap
The novas are simliar body pieces. I did some rust repairs to the front cowl/ firewall on my 72 nova and the replacement patch was a 69 camaro piece and a perfect match, as were the toe boards on the inside of my car. My supplier was out of the " nova " tagged parts at the time. I was a little concerned before I got them home to compare the "camaro" parts to my car.
The early Camaro and Nova subframes are the same also, as long as it has the back mounted steering box instead of the forward mount. Rear axles are the same. Floors and firewalls are the same. The wiring harnesses....maybe but I can't comfirm that. Someone else may know.
Also FYI I purchased a better condition heater box for my 72 Nova at a U-Pull-It yard, I removed it from a 79 Chevy Concours, which is just a Nova with a name change. It also was a match but for being 7 years newer and more available, not to mention much cheaper than a reproduction. I spent 20 bucks instead of 250.
Old 11-21-2010, 01:13 AM
FastOrange's Avatar
big block or small block car?
Old 11-21-2010, 09:19 AM
302 Z28's Avatar
Why if your restoring a 69 Camaro would you even consider anything but a 69 Camaro heater/AC box?
Vince
Old 11-21-2010, 11:04 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Vince
X2 If you are restoring it then pretty much all the parts a available for you car, No need to hunt around for things that might fit when you can get the parts that will fit. JMO
Cole
Old 11-21-2010, 02:03 PM
ericnova72's Avatar
More for Less Racer
'68-79 Nova, Omega, Ventura, Apollo is identical.
Old 11-22-2010, 03:54 PM
FastOrange's Avatar
the reason i asked if its a BBC or a SBC camaro is this...
The heater box is different on a big block car, well at least the heater core and the cover thats in the engine bay, the two nipples for the hoses for the heater core are in the middle not the side, to clear the valve covers of a BBC car.
Camaro front end swap help Augusto Suspension - Brakes - Steering 9 09-28-2007 09:17 PM
2.8 to 350sbc swap in 91 camaro streetmaster42 Electrical 7 07-26-2007 08:13 PM
Anyone know a good place to find Camaro Parts? TooTallCeltic Hotrodders' Lounge 1 02-21-2005 12:15 AM
79 Camaro big-block swap 79454 Engine 4 01-04-2004 07:09 PM
1989 Camaro Engine Swap Help! rollin89camaro Engine 2 10-03-2003 12:11 AM
