parts washer - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2004, 08:21 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
parts washer
i have a stainless steel tub with a hinged cover and a center drain at the bottom, i'm going to make it a parts washer, i already have a pump the question is do i need some type of gasket or rubber molding around the top to keep fumes in ? and if i do what type of rubber or foam do you yhink i should use? thanks for your help.
Old 09-15-2004, 06:03 AM
BOBCRMAN@aol.com's Avatar
No rubber gasket will last if you get a potent cleaning solution in the tank. Are you going to heat the cleaning solution? I keep my hot tank in a shed outside the main working area. The fumes from the hot solution can get intense..
Old 09-15-2004, 07:42 PM
helrazr3's Avatar
no i wasn't planning on heating it up. what do they put on the parts tanks you buy? iv'e never looked and i'm not near one.
Old 09-16-2004, 01:51 AM
Old enough to know better
Mine just has a metal cover with the edge turned down over the tub, no gasket or seal.
Old 09-16-2004, 01:26 PM
Get saturdays paper and look for used dishwasher - usually $25-$35. Give it a shot of Simple Green or your favorite... and let it rock. Don't use the one in you kitchen!
49 T&C
Old 09-16-2004, 09:07 PM
helrazr3's Avatar
i've heard about the dishwasher trick before thanks for the info
rich
