-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   parts washer question (http://www.hotrodders.com/forum/parts-washer-question-215461.html)
buicfrank 02-26-2012 02:32 PM
I am replacing the motor on the parts washer. Air to electric. Does the replacement pump sit in the fluid covered all the way over the top? Or is there supposed to be a metal box around it for any reason? Could I just use a metal band around the pump to anchor it to the washer tub? Thanks Frank
27Tall T 02-26-2012 09:32 PM
:welcome: I have my motor just sitting in the tub and hanging there by its cord. It does have to be covered at all times by the cleaning fluid. If you're running water in the washer make sure that the motor is mounted in the layer where the cleaning fluid is and not in the water. Been running my system for 9 years and have never had a problem. All the sediment and gunk falls into the bottom and in no way comes in contact with the pump. Cleaned my tub about 3 years ago and took out about 2-3" of sludge. :pain:
buicfrank 02-27-2012 07:13 PM
Thanks for the reply. That's what I needed. Frank
