Without getting too technical, pH is a measure of acidity or alkalinity (acid/base). Neutral is 7(water), each number is a 10 fold increase so that 6 is 10x as acidic as 7, 5 is 100 times as acid ,etc. so looking for compounds bewteen 6 and 8 is pretty much looking for neutral compounds. Your degreaser should have that info available either on the label or through the manufacturer. You can check out their MSDS (Material Safety Data Sheet) on line and find this,too. You could also call the parts washer manufacturer and ask for specific product recommendations. Not to your point at all, but it would be interesting to know if the recommendation on pH was made for operator and environmental safety considerations, or because your equipment has some factor that will not stand up to caustic material exposure. Let us know what you find out about the cleaners.
