I just got through cleaning out my parts washer (metal) and need to refill it with cleaning fluid. I can't use a water base because it would rust the tub. Is kerosene safe or is it dangerous with the electric motor powering the pump. I don't think there is ever a spark, but, the shop is in the basement under the house so I don't want to take any chances. How about half kero and half fuel oil? The parts washer says fuel oil is okay but I just don't know about kero.
If the pump is a properly rated submersible parts cleaner pump then I don't think there is much to worry about. The washer should have a steel lid with a low melting point link in the support mechanism. If there is a fire you would close the lid to extinguish, and if you are not there the link melts and the lid should close closes by itself.
I use mineral spirits with a layer of water on the bottom, the evil bits in the solvent settle and are trapped in the water, it keeps your solvent cleaner longer. I like my parts to dry without an oily film so for me kerosene and the like is out.
Glenn
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
