Parts Washer Safety - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2010, 04:18 PM
Parts Washer Safety
I just got through cleaning out my parts washer (metal) and need to refill it with cleaning fluid. I can't use a water base because it would rust the tub. Is kerosene safe or is it dangerous with the electric motor powering the pump. I don't think there is ever a spark, but, the shop is in the basement under the house so I don't want to take any chances. How about half kero and half fuel oil? The parts washer says fuel oil is okay but I just don't know about kero.
Thanks in advance for any info or opinions.
Old 03-15-2010, 04:36 PM
BOBCRMAN@aol.com's Avatar
Since the mid sixties I have used mineral spirits in parts washers. No problems. Wear gloves. The spirits dry out your skin.
Old 03-16-2010, 06:51 AM
i also recommend mineral spirits, go for the low odor kind.
Old 03-18-2010, 01:56 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
most parts washers have the magnetic drive pump, No sparks.
Old 03-18-2010, 05:11 PM
Proper parts washer or ?
If the pump is a properly rated submersible parts cleaner pump then I don't think there is much to worry about. The washer should have a steel lid with a low melting point link in the support mechanism. If there is a fire you would close the lid to extinguish, and if you are not there the link melts and the lid should close closes by itself.
I use mineral spirits with a layer of water on the bottom, the evil bits in the solvent settle and are trapped in the water, it keeps your solvent cleaner longer. I like my parts to dry without an oily film so for me kerosene and the like is out.
Glenn
Wiring Neutral Safety Switch / EZ-Wire Kit horvath Electrical 15 01-20-2008 12:35 PM
What Is It With Me And Parts.... BigBlockBabe Off-Topic 5 09-11-2007 11:14 AM
Sanding the *%^$&# primer all off the fiberglass parts Ripped Body - Exterior 7 09-01-2007 07:56 PM
Parts cleaner BMM Hotrodding Basics 13 10-19-2006 08:39 PM
Tips on chromed parts ckucia Body - Exterior 10 02-04-2005 11:02 AM
