Parts Washer Solvent? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2004, 03:56 PM
Last journal entry: Transmission Table
My dad found some lady that her husband died a year ago, so she is selling his stuff from his shop.
My dad bought their 4 post (drive on) for $500, and then he got me a like 24 x 36 Snap on parts washer for $75, and a vacuum pump for AC work for $10.
I am so excited! Lol, the simple things in life.
But anyways, what's the best solvent to use for parts cleaner? A place I used to work used a paint thinner and kerosene mix, but it didn't seem to work all that great. I talked to a buddy a year ago that was selling zep products, he said that they sell some stuff that is awesome. But I am hoping that maybe someone knows something for sure, or has a recipe for something good.
Thanks in advance.
Old 12-09-2004, 04:01 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Just head to the local parts store. They sell it in 5 gal. or 1 gal. cans. Don't use the Kero / thinners. Not good for the body. Also keep some rubber gloves at the parts washer. Keeps the hands clean and the chemicals out. BTW..tell dad I'll give him $500 for the hoist Good find!!!
Old 12-09-2004, 04:25 PM
I'm thinking he needs to put the 4 post at my warehouse. I have 12,000 sq ft available to me He is going to keep it outside in his car port, which he hasn't poured the concrete for yet...
Maybe santa will bring me a lift courtesy of step-dad's business account, they need one to work on the work trucks, yeah, that's it.
Old 12-09-2004, 06:23 PM
302 Z28's Avatar
Varsol is made by EXXON/Mobil and is an excellent solvent, pretty reasonably priced also. I do not know if it is flammable or not, but you should take that into consideration, if the parts washer is motorized.
Vince
Old 12-09-2004, 06:27 PM
I use mineral spirits in mine. I buy it in bulk,5 gallons at a time from local petroleum/pool supply.
Old 12-09-2004, 07:07 PM
adtkart@aol.com
If you can find someplace to buy it, I would go with the varsol. That is what we used at the transmission shops that I used to work at. It is really strong, and doesn'd evaporate very fast. I don't believe that the fumes are flamable, because we used to smoke while working in it. It will dry out your skin real fast. It is great to clean dirty rags in also. It seems to me that it is the same stuff that they used to use as dry cleaning solvent.
Old 12-09-2004, 10:11 PM
sbchevfreak's Avatar
Licenced Automotive Technician
The dry cleanung solvent is the same as brakleen, evaporates very fast and is super expensive. Varsol will burn, but more like diesel fuel than gas, not a very volitile substance. If your washer is motorized, and is reasonably new (25yrs or so) you will have no problem with it, as it was designed to run with varsol type solvent. Record Chemical makes a "solvent" that is less expensive than brand name varsol, and is virtually identical. It is what I use in my shop, and most dealers use it here for the price cut, as well as most training facilities. (not nessicaraly(sp?) the recochem stuff, but any of the various jobber names out there). One tip, though. If you have a solvent spray gun and use it a bit, don't get the enviromentally friendly stuff. If you inhale the misted form of it while spraying, you can get hospitalized type sick, with lasting (maybe permanent) side effects. Nasty sh1t. Sure, save the enviroment, kill a gearhead? Typical non-logic!
Old 12-10-2004, 12:48 AM
Old enough to know better
I'm not sure what mine is. Local petroleum bulk plant just has a pump out with the others that says "SOLVENT" on it. 2 bucks a gallon, bring your own jug.
Old 12-10-2004, 07:00 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
I use mineral spirits.
Old 12-10-2004, 04:03 PM
me 2, mineral spirits cost more then paint thinner and I understand it leaves no residue and smells a lot less bad. Ed ke6bnl
Old 12-11-2004, 05:17 PM
Thanks guys!
Old 12-11-2004, 08:58 PM
302 Z28's Avatar
I do not know what dry cleaners now use, but they used to use carbon tetrachloride which has since been banned. It is classified as a carcinogen and harmful to the ozone. The synthetic rubber unit I work on uses carbon tetrachloride as a solvent to dissolve polyethylene pellets. We had to get an exception from the EPA to keep using it and we only got that exception because we recover 98% of it.
On Varsol, it will dry your skin very fast. When I was working as a Ford mechanic I had a 5 gallon pail of it at my work bench. When I got a rear end to overhaul I used to dunk the parts in the bucket to clean them. I did not use gloves. That was almost 30 years ago, so far no adverse affects Wear chemical gloves.
Vince
Old 12-12-2004, 03:56 AM
Kevin45's Avatar
What 302 stated...Wear chemical gloves. Also Varsol is flammable. On the MSDS sheet it specifies to keep from open flame or spark as it is a petroleum distillate. Here is the MSDS sheet on Varsol: http://www.daycon.com/MSDS%20Sheets/varsol%20msds.pdf Also here a site where you can get an MSDS sheet on a variety of things. http://www.daycon.com/ttoz.htm One might not think it important for the gloves, paint mask, etc but when you get a little oldder and different symptoms show up it makes you woonder if it had something to do with things you took for granted in your youth. Better safe than sorry. One other safety measure I would like to bring forth is kids and garages and chemicals. Almost everyone knows to keep chemicals out of reach of kids. Everyone really needs to (especially if you have real small children) keep the phone number of the nearest Poison Control Center ( You can get it here ) near the phone in the garage. Also it used to be the norm that if something was swallowed to give Ipecac to induce vomiting. That is not the case now. Sometimes it can actually do more damage to induce vomiting. So those with small children...keep the garage safe and think of them.
Old 12-12-2004, 10:33 PM
Don't forget about your pets either. My son left the back garage door open accidentally. A little later, I found one of the dogs dragging a quart can of paint remover around the yard. Lucky for us, it must not have tasted to good so he didn't chew it up.
Old 12-13-2004, 04:13 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
A little off topic but the carb cleaner (1 gallon can) sold at Advance Auto Parts is awesome. It isn't something I'd use in a parts washer but for carbs and other small parts the stuff is great.
