Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pass Front Tire out of alignment?
Old 03-17-2013, 08:28 AM
Hugger355 Hugger355 is offline
Originally Posted by aosborn View Post
Check the wheelbase and see how far off it is. How does it drive? Does it pull to one side or other? Are the tires wearing unusually? If the subframe bushings are good, and the subframe itself is good, then it has to be the control arms or control arm bushings. You musta hit something, or someone else did when they borrowed your car...
I'll check the control arms or bushings.
I don't think anything was hit, I was parked driving fine, then after sitting for a bit it rubbed the first drive out. Either way, I don't mind replacing parts, I just need to figure out what's wrong.
How can I check the control arms and bushings? I assume just for the bushings just look to see if they're dry rotted.
It drives fine although it does pull a little to the right. Which is when it turns on right turns.
