Passenger side dip vs driver side dip in early Nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2008, 12:12 PM
*** Please post solutions ***
Will a 207 cast block (pass side dip 80-85) fit in place of an 010 drivers side dip, interchange into a early 60's Nova?
BTW this is a 350 chevy small block
Old 11-20-2008, 12:45 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Probably not. The problem is with the oil pan. Novas take a specific pan that is only made for the driver-dip block. I have seen pans with both bulges to fit either block, but I've never seen a Nova pan with both bulges.
I would check with Milodon or Stefs. They both make a wide variety of pans for engine swaps. If anyone makes one, they do.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
390 smoking on driver side old fords Engine 4 09-14-2008 08:36 PM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
driver and passenger side window removal wrecknracer Interior 1 11-16-2001 02:16 PM
