Passing aircare? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2009, 10:35 AM
Passing aircare?
hey guys could you give me some tips on how to "make some adjustments" on my 383sbc camaro to pass aircare? It has a holley 670 street avenger carb and base timing is at around 12 degrees. I doubt it would pass air care with this much advance so what should I do to help my chances? I was told to lean it right out and retard the timing but more specifics would be great.
Thanks,
Keith
Old 03-28-2009, 04:03 PM
nitro_baller4692's Avatar
floppers forever
Thanks,
Keith
smaller jets and back the timing down to 8*
Old 03-28-2009, 11:15 PM
Is that right? You can use a dgital multimeter and a narrow band O2 sensor? Can this be used as a tuning tool? Any stock sensor will read .45 volts at 14.7?
Old 03-29-2009, 12:25 PM
Will it matter that this is a 383 and not the lame 350 that came stock in the 1980 z28? What I'm asking is do they measure how much (quantity) of exhaust is coming out your pipes or is it the ppm of the greenhouse gases they are looking for? If they do measure the quantity of exhaust coming out of the pipes I'm sure a 383 will push out dramatically more than the stock 350. Also I am not very good at tuning carb's and I haven't touched this 1 since it came new out of the box, just bolted it on and adjusted the choke. It is a holley 670 street avenger vacuum secondaries and is said to be tuned at the factory for most applications, do you think by backing off my timing I would porbably be good enough since I am not quite sure how to lean out a carb to be honoust with you.
Thanks,
Keith
could it pass...... aircare?? sexypizzaman Engine 4 01-07-2009 08:32 PM
passing emissions with race car mitmaks General Rodding Tech 39 12-07-2006 07:25 PM
Aircare question for anyone in the Vancouver area Acadian Engine 2 05-23-2005 11:32 PM
Passing Gear Leak..Plz Help 7skylark6 Transmission - Rearend 2 04-03-2004 11:07 PM
How to hookup passing gear to carb? clayboy Transmission - Rearend 4 09-20-2003 08:38 AM
