Patch leveling question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2005, 01:49 PM
This is such a simple question, I have searched, and can't get my mind around it. So forgive me if it is already asked.
When welding a patch, either but, or overlap, you end up with the weld bead being proud on the seam. Kind of like this.
When grinding the bead down do you grind it completely flat eventually? Or just close to the surface?
Either way how do you fill this uneven surface so that it doesn't show in the finished product... In other words, if the weld is left a little prowd, do you just feather the filler out far enough so that you cant see it? Or do you tap it down, and fill flat? Or?
Hope some of this makes sense.
Dale
Old 05-18-2005, 03:15 PM
302 Z28's Avatar
The weld is ground flush and any filler material that is used should be minimul. Take care when grinding as excess heat can warp the metal and then you have that to deal with.
Vince
Old 05-18-2005, 04:06 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Nice camaro project
What we attempt to do is get a good penetration to our welds..look at the backside to see if you are..
It is Ok to take some scrap and weld on that till you can get it right..
When the weld sticks up we call that cold and ropy..looks like a piece of rope laid on the panel..
welds sticking up is caused by too little heat..too much wire speed..or too slow welding doen the seam and building a high bead..If everything is going your way the weld bead will "lay down" and not require a lot of finish work..some hammer and dolly or a quick pass with the sander will get it..
When the weld is done to your satisfaction then go ahead with the epoxy prime and check it as you may need to use a tablespoon or so of fill..
Hope this helps..Good luck
OMT
Old 05-18-2005, 05:39 PM
A little more clarification.
Thanks for the help guys.
I can get the weld ok... Not great, but it does have good penetration. I guess I wasn't sure about the grinding part. Sounds like the weld after grinding needs to be at or below the level of surrounding material? Then just a dollop of filler will do. However, doesn't grinding the weld area a little shallower cause the patched area to be weaker?
I am a long way from finishing metal like Randy has done.
Dale
Old 05-18-2005, 06:27 PM
Wiki Edits: 3
die grinder
One of those little angle head die grinders is just the ticket..grind down flush (just flush is perfect)is all and not into the base metal..if all you can do is just catch the weld with a finger nail then you should be fine..
you will get the hang of it soon I am sure...
OMT
Old 05-18-2005, 08:44 PM
Grind the weld down till the abrasive just starts to contact the base metal- you don't want to cut into the base metal and weaken the areas around the weld, then clean the weld area completely with a clean and strip disc or wire wheel and prep for epoxy primer or bodyfiller. An air angle die grinder with a 3" disc will give you the control you need to precisely grind the welds.
Question on welding patch panels? sled51merc Body - Exterior 39 01-30-2005 11:56 AM
PPG epoxy patch question (help asap pleaaaase!!) BrandonMiller Body - Exterior 9 11-01-2004 09:14 PM
Quarter Panel Patch Ron M Body - Exterior 1 07-27-2004 01:12 AM
Hotrodders Guidelines -- READ ME Jon Engine 0 06-14-2003 04:53 PM
