patch panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2007, 12:30 PM
patch panels
looking for a better way cut out for a patch panel. i`am doing door bottoms. i did one door allready. my first.hope to start the other door next weekend.thanks.no welding experience.just jumping in there.1962 gmc surburan
Old 02-05-2007, 01:12 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I'll tell you what I do-I will make certain the Patch Panel first fits the contour of the Body (Panel Lines, right curvature,etc.), then I will use a Clecos (or Sheetmetal Screws) to hold it in the proper place-I use a thin cut-off wheel to make a slit so I can insert my air-powered Hacksaw. Then, I will saw about 3-5" (or more), make certain the Sheetmetal is flush, Spot Weld and move on until the Panel is Attached. If I have planned correctly, the old Panel will just fall inside of the Car-make sense?
Old 02-06-2007, 04:15 AM
patch panel
that will not work because it is a inside door bottom and does not slide over to hold in place.thanks
Old 02-06-2007, 09:40 AM
35WINDOW's Avatar
hdbiker,
I am sorry, I didn't read that it was an Interior Panel. On mine, the inside Door Panel was curved to mate with the outer Door Skin. I'm certain there is a better way, but I made a "flexible shape pattern", located it on the Door, marked it and cut it just shy of the marked line, then snuck up to the line with my Roloc Discs and Files and then welded the inner Door Panel-maybe there is an easier way-hope this helps.
Here is a Link as to how to make a flexible shape pattern:
http://people.delphiforums.com/snotz...erpatterns.htm
By the way, you are butt welding this-correct? Or, are you flanging it?
Body patch panels DagoFred Hotrodding Basics 8 09-22-2010 03:13 PM
I need help with fender patch panels. unstable Body - Exterior 6 03-28-2005 08:27 PM
Brazing body patch panels? rlackey Body - Exterior 5 03-04-2005 01:05 AM
Question on welding patch panels? sled51merc Body - Exterior 39 01-30-2005 11:56 AM
Fiberglass patch panels? flamedfordbronco Body - Exterior 7 04-10-2004 06:29 PM
