patching up trans cooler - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2006, 10:32 AM
53LEDSLED's Avatar
here to learn
Last journal entry: finishing up the skirts
i busted my radiator for my trans cooler and i was wondering what was the best way to fix it. its a small tear about 1/2" long and 1/8" wide. can i TIG this thing shut or can i just use some of the welder's putty, OR buy a new one for 163.
ps i did this when i bottomed out going off road. on top of this problem i no longer seem to have Power brakes or power steering. what can cause this. there are no busted lines or blown fuses.
Old 07-24-2006, 11:57 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
1) depends what it is made of
If this all happened at once you need to look around and see what got fragged.
Old 07-24-2006, 12:10 PM
Not A T 25's Avatar
Takes Guts To Cut One Up
Trans Cooler is no place to skimp if you loose it you will trash the trans I would take it to a trans shop or just bite the bullet and get a new one. As far as the other problems what kind of vehicle is it need more details. Possibly if you blew the cooler you could have sprayed trans fluid on the belts causing them to slip?
Success is getting what you want but happyness is liking what you get.
Old 07-24-2006, 02:00 PM
53LEDSLED's Avatar
here to learn
sorry, its a 99 f250 diesel 2wd. i checked the belt and its OK. i did notice that it has one pump for the steering and brake booster.
the radiator is aluminum.
Old 07-24-2006, 04:00 PM
Not A T 25's Avatar
Did you get trans fluid on the belt which will allow it to slip on the pump pulley?
Old 07-24-2006, 05:01 PM
53LEDSLED's Avatar
here to learn
nope, all clean.
Old 07-25-2006, 01:24 AM
Where's my Sawzall?
Last wiki edit: Window removal and installation
Last journal entry: More progress...
Wiki Edits: 2
Not the trans cooler...
That cooler is for the power steering fluid, which also runs the Hydroboost for the brakes.
I would just get a small tranny cooler and reroute the lines to it instead. Most tranny coolers from the aftermarket will be a bit larger in size, and keep the power steering fluid a bit cooler, in addition to holding a bit more fluid.
Use good hydraulic hose made for the job, not fuel flex line. And I would double-clamp the rubber lines with fuel injection-style clamps as these hold better and make a more positive seal.
Trans. cooler lines Novaman78 Transmission - Rearend 12 10-08-2006 08:15 AM
What size trans cooler do I need? 84Z Transmission - Rearend 19 11-12-2005 07:18 PM
Can I use a trans cooler only without a radiator cooler? supercab78 Transmission - Rearend 5 04-14-2005 02:46 PM
air conditioner rad for trans cooler? cboy Transmission - Rearend 15 01-17-2005 03:53 PM
Trans cooler hook-up???'s juveteach Transmission - Rearend 9 09-15-2003 04:23 PM
