Patina paint....tips - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2008, 04:48 PM
kruzr's Avatar
street rods forever
Patina paint....help
I have a 37 Ford pickup under construction, want to do a patina paint job.
Truck will probably be close to original green,with red oxide coming thru.
Question is... should I paint it brown first then the green?
What's the best way to get the effect??? Just buff it or sand thru the green till I get the effect I want.........
Jerry
Old 09-18-2008, 08:42 PM
AntnyL's Avatar
I've never done it before....on purpose anyway! But I would lay the "primer" color down first, color coat and clear it, sand it to get the effect you want, then reclear it. Hope this helps.
Old 09-19-2008, 08:28 AM
forestrytodd's Avatar
Official Hotrod Forester
I helped a friend do his patina on a 66 chevy truck.
We sprayed black epoxy prime first. Then paint the base color that you want to show through. Ours was black. Then paint the top color. Ours was red. These were done in single stage urethane. Now get out the 1000 to 1200 grit sand paper and start sanding. Heaver here, lighter there, until you get the look you want. and stop there. As long as you do not sand through the base color than you are fine and do not have to clear the paint because its single stage. With this kinda job if you want a mat finish and you clear it, you'll have to use a flattning agent in your clear.
Old 09-19-2008, 10:03 AM
kruzr's Avatar
street rods forever
Thanks guys.... I've never done it on purpose either but would like something different. The truck belong to my bud 50 yrs ago ,was his service truck so I'd like to put it back the way it was only newer
The pic shows the effect I'm after.
Cost of paint Job - complete do it your self job at home Warrant Body - Exterior 74 07-13-2006 09:31 PM
Paint flow and gun control tips! camaro freak Body - Exterior 9 05-17-2006 09:43 AM
HELP!!! need paint tool tips billszoo1 Body - Exterior 2 05-06-2006 09:54 AM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
