Patriot Headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2009, 06:22 PM
Patriot Headers
Anybody tried Patriot headers? The price is in my range and they are ceramic coated and are supposed to be a lifetime guarantee. It kinda worries me that they are only 18 gauge and 5/16 flanges though. Any suggestion? The Sanderson headers are just SO expensive! In canada they will cost me $550 plus tax!
Old 08-24-2009, 06:39 PM
techinspector1's Avatar
Wiki Edits: 326
Yeah, it would worry me too. You get what you pay for.
Old 08-24-2009, 06:57 PM
BOBCRMAN@aol.com's Avatar
I bought Patriot sprint style roadster headers for my "T" bucket. They fit great. No problem with the flanges even tho very little bracing at the collector/muffler and are totally exposed to elements.
BAD part. I made the mistake of getting chrome plated headers. While they did look great during the summer. Minimal bluing and cleaned up with little effort and a bottle of spray wax.
I stored the car in a semi-open shed thru the winter. The chrome literally fell off the tubes and rusted heavily in the inaccessible areas. I had cleaned everything in the fall and coated the pipes in spray wax.
Maybe the coated pipes will not have the problem.
Old 08-24-2009, 07:15 PM
DoubleVision's Avatar
I paid over $400 for jet hot coated Hooker headers for my cutlass. Within a week you could see the rust coming through the surface of the finish. Needless to say, the engine build was a bust due to a major mistake my machinist made that I didn`t catch, so the headers only have 2000 miles on them and you can still see the rust bleeding through the finish with no way to get it out.
Old 08-25-2009, 01:43 AM
327NUT's Avatar
I had a set but they wouldn't fit my application...my fault. They were made very well and the welding inside the ports was MUCH nicer than my Sandersons. If you can use the "Tight Tuck" model which is basically a block hugger they have a couple made with 16 ga. tubing and 3/8 flanges. See www.Pertonics.com then hit Patriot headers for the modle number.
Old 08-25-2009, 04:05 AM
ericnova72's Avatar
More for Less Racer
327Nut, your link is misspelled, no worky - always check them after you post them.
Old 08-25-2009, 08:51 AM
daoldbuick's Avatar
Confused as to were you got the lifetime guarantee from. I took this off the patriot site "All Patriot exhaust products are guaranteed, to the original purchaser, to be free of defects in materials and workmanship for one year." Is it your dealer giving the lifetime guarantee?
Old 08-25-2009, 12:25 PM
Even Jet Hots warrenty is very specific about cleaning and care. If the headers are overheated(like during cam breakin), the coating will fail. Oils and other fluids will attack the coatings, causing rust and adhesion problems.
these coatings can work really well, but they are definitely not an install and forget item, it requires regular maintenance
Old 08-25-2009, 03:22 PM
I installed some sanderson headers in a 69' Camaro with 396 and they were the worst set of expensive headers I ever worked with.
The drivers side collector pointed right at the frame and required a 90 degree bend to route the exhaust towards the back of the car, the flanges hit the head bolts, They were waaay too close to everything under the hood. Took me like 14 hours to install them & the exhaust including removing the old original parts.
I say give them a try....I'd go for stainless if you can find them...Best deal overall but those cheap headers are so thin that they dont sound as good as the real deal. Thin headers to me always sound like they have a exhaust leak (tinny). Also throw the gaskets in the garbage when you get them and use RTV Silicone to seal the headers to the block. It saves alot of headaches.
Old 08-25-2009, 04:31 PM
Ya I was wrong about the warranty but I bit the bullet and ordered the sanderson headers. I sure hope they work properly! How hard can it be to make a good set of block huggers? RTV works well for sealing against aluminum to?
Old 08-25-2009, 06:51 PM
Sealing Heads to Headers. Use a gasket that cannot "blow out." That's why copper gaskets are so popular in spite of their price. Use header bolts that cannot unthread. I use Stage 8s. You might want to try them, or use cross-drilled heads on a more traditional header bolt. Use lockwire with the cross drilled heads. About the Stage 8s. They are very expensive. But when I needed longer bolts, I just called, they had me send the too-short bolts, and the longer ones magically appeared in the mailbox. When I lost some locking elements, they charged little or nothing to send me a few. Great customer service.
Pat
Old 08-26-2009, 03:25 PM
Most good aluminum heads have steel heli-coil inserts in the exhaust bolt holes.
I have never had a issue with a header bolt coming loose while using RTV as the gasket, But when I did use the gasket they came loose all the time.
DONT WASTE your money on copper exhaust gaskets. Just use the Aluminum RTV from Valco or the Copper from Permatex. It doesnt matter if the heads are Aluminum or cast iron.
The stage-eight bolts are not cheap. If you use RTV as the gasket the headers sits basically right on the head except for the thin coating between. The joint is much less likely to move at all and there is no gasket to expand and contract. plus the weight of the header and exhaust is supported better. With the gasket in-between it just requires the bolts to hang out further and then there is more flexing and movement going on and BAM then it leaks.
The dead soft aluminum exhaust gaskets are a even bigger joke....Autozone sells then right next to the locking bolts....Talk about a flexy joint and leaks....I'm not saying locking bolts are bad...Just not really needed.
Old 08-26-2009, 03:49 PM
With all due respect to Montebrian, I recommend you DO "waste" your money on high-quality copper gaskets and mechanically secured header bolts. A difference of experiences, a difference of opinion. Whatever you choose, best of luck.
Pat
Old 08-26-2009, 04:00 PM
I have plenty of experience....On the 4 cars I own, and on the dozens of cars I have built exhaust systems for.
I do mandrel exhaust systems for friends and friends of friends.
Old 08-26-2009, 05:37 PM
I give up.
What has been your experience with headers compaired to stock exhaust manifolds?? Jim Weeks Engine 10 10-06-2012 12:21 PM
Patriot Clippster Headers lt1_performance Engine 0 12-30-2007 10:48 AM
Patriot Headers theclaw1 Engine 2 12-07-2007 06:54 PM
making custom headers??? aztek_warrior Engine 2 07-11-2006 11:13 PM
Patriot Headers for a Tri-5 Stroker56 Engine 1 03-02-2006 09:55 PM
