Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - patriot heads
Thread: patriot heads
Old 08-08-2012, 07:01 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
maybe you dont need even those cheaper patriots? what are you building? and egine costs are about the same no matter if its blue printed stock or a little warmed up. Machining is the same,both engines get a new cam and bearings and pistons and gaskets, rebuilt heads are part way to improved heads,perhaps just cleaning up what you have is enough with a slightly bigger cam. better ignition is required for high perf,,,,what ya trying to make?
