Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - patriot heads
Thread: patriot heads
Old 08-09-2012, 02:15 AM
killab1989 killab1989 is offline
Well i dont kno all da correct specs but a buddy is helpin build a 383 stroker. We went over the set up with summit they sai i shud perform 650hp. 208 aluminum 64cc heads with one eye brow flat topd forgrd pistons with forged i beams then the solid roller cam has a 680 lift which makes me have to have at least a 4000stall in a turbo 350 with a shift kit in it then have posi 4.10 gears to hold the rear end right which ima get new shocks nd tie the frame in to hold that power from twistin the frame....nd thanx for not knockin on me askin bout the heads or talk to me lik im stupid....i got the moneyo build a fast car but im not a rocket scientist bout buildin a fast *** car....the car this is going in is a z28 camaro t top. I kno not the best car to pick for the motor im buildin but i love camaros specially it being t top. ooh nd the carb is a 750 double pumper and the whole car is roller
