If you seriously want 680 hp then you need to do the car first.tie the subframes,good traction bars that are tune able,the diff will need gears and a good centre section and c clip eliminator axles,drive shaft loop, transmission will need all the good parts to live behind that much power, roll bar is a good idea if you want to race,50/50 rear shocks... front suspension will take some planning,,,depending on if the car is driven on the street a lot.drag cars do not corner well,sports cars do not hook well. You have some work ahead of you,good luck and keep us posted with your progress.
