-   -   PAW 388 or 383 kits, any good (http://www.hotrodders.com/forum/paw-388-383-kits-any-good-57983.html)
rick458 02-12-2005 12:24 PM
I did a search but didnt see any applicable threads, So, Has anybody tried the PAW 388 or 383 stroker kits were they any good, and unecpected problems?
I will go with a comp cam and lifters, and would probably use AFR 195 heads, and going for a daily driver more than a DAIRY queen
so I wont be after Monster power just great torque and streetability.
69er 02-12-2005 02:46 PM
paw
I know it's not the same, but for what it's worth, I bought a 427 paw engine kit for my Corvette and things turned out real well. I was happy with their flexibility and help putting my kit together. This engine is way more brutal than my last one.:pimp:
rick458 02-12-2005 02:51 PM
Did you do the long block or the short block?
69er 02-12-2005 03:26 PM
paw
I bought their entire 427 long block kit except for the heads. I had a set of 396 heads that had been ported, so I put some 2.19 & 1.88 valves in them, and used my heads. PAW did screw up on the proper valve guides, though, so I called them, and they sent the right ones right away. I paid extra for a .030 bore block, instead of the .060 over. I think they messed up on the guide plates because I upgraded the pushrods to the 7/16 chrome moly ones. I also upgraded to some roller rockers instead of those long slot jobs. I also got a xe268 comp flat tappet cam, that I really like too. With the 4 bolt mains and all I feel more confident romping on it now. It has killer low end and really screams. I put a shift kit in the 400 tranny too with a Hughes convertor, and now I'm worried about breaking the u-joints or rearend. Compared to my last engine, this one is almost scary. I give PAW a thumbs up, and of course my machinist deserves a lot of credit too.
