Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - PB vacuum hose size?
Old 06-04-2012, 11:18 AM
Leakie's Avatar
Leakie Leakie is offline
I am putting a street rod together and the fitting on the master cylinder booster is for 9/16 vacuum hose and the fitting on the engine is for 11/16 hose. I have a 11/6 fitting for the booster, does it make a difference? Or Should I change the engine fitting to 9/16 and run 9/16ths hose? The master is under the floor.
