PCV, breather, filler cap question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2007, 08:44 PM
BMM BMM is offline
Hello. I have a set of Moroso valve covers Ive been thinking of putting on my engine. However, they are bare.
There is a single hole, that looks like it is for a filler cap. Will a filler cap seal properley, or is there supposed to be a grommet in there?
Can I use another hole and put a breather on there to remove my PCV valve? Or, do I want to keep the PCV hooked up?
Also, should there be a baffle or something to prevent oil from splashing up into the breather?
Thanks alot.
Old 07-05-2007, 09:04 PM
? #1: They will probably need a grommet. Unless you find the right size breather.
? #2: It's up to you. But if you like a clean engine you need a PCV valve or a evacuation pump of some sort to keep the pressure down in the crank case. If you don't you will probably have at least seepage if not full blown leaks.
? #3: Yes. If you don't the engine will suck a lot of oil if your using a PCV valve.
My 2 cents. Hope it helps!
Mark.
« Chassis Q | 302 »
Plastic filler tips. MARTINSR Body - Exterior 14 03-03-2009 06:11 PM
Radiator cap pressure question wheel-7 Engine 9 10-11-2005 12:14 AM
PCV system question? M&M CUSTOM Engine 13 05-06-2005 10:49 AM
Got a filler question here Bluepen Body - Exterior 2 04-18-2003 05:40 PM
Oil Filler Question horvath Engine 2 03-17-2003 02:52 AM
