PCV Breathers SBC - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-28-2011, 11:48 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by alexcamaro307
Here's a page of the Holley manual of my carburator, and also a picture of my carb. I marked the PCV inlet in the carb, that's what i think the hose can be hooked in...
Is this the correct PCV inlet to hook up the hose from the PCV breather?
Yes that's the correct place for your pcv. As far as those breathers Sqz is right if they don't have a built in pcv then they are a waste of time and money.
Cole
  #17 (permalink)
Old 04-28-2011, 01:52 PM
alexcamaro307's Avatar
the guy lied to me, the pvc breather does NOT have the PCV valve, it sucks!!! it is just a tube or a open simple breather, i need my crankcase to breathe properly...im so f...... pissed off...
Guys, can you tell me where and if i can buy the pcv valve only and put it inside this pvc breather? :
your help is appreciated
Alex
  #18 (permalink)
Old 04-28-2011, 02:20 PM
his answer was that :" you won't suck oil, only the vapors and the factory has done it this way"
Also:" that ones they sell come without a pcv valve. Doubt anyone makes them with a pcv valve. The pcv valve does not affect the performance of the vehicle, its for emissions only. A simple example is just by looking at all the aftermarket valve covers out there that do away with the pcv valve.
That was his explanation, what do you guys think?
  #19 (permalink)
Old 04-28-2011, 02:24 PM
eloc431962's Avatar
Wiki Edits: 37
You can get regular pcv valve at any parts store, drill the hole and put the groment in and then the pcv valve and run the hose to the port on the front of the carb.
Cole
  #20 (permalink)
Old 04-29-2011, 05:55 AM
Ok, this is the bottom of my carb, i have to run a hose from the breather to the large port in the carburator right?
ID:	54839   Click image for larger version
ID:	54840   Click image for larger version
ID:	54841   Click image for larger version
  #21 (permalink)
Old 04-29-2011, 03:49 PM
eloc431962's Avatar
Wiki Edits: 37
Yep that's correct hook to the large port.
Cole
bolt on breathers brickhead Engine 1 08-09-2009 05:24 PM
pvc's and breathers? chewyscool Engine 3 12-16-2008 04:13 PM
oil comming out og the breathers mac350 Engine 23 06-26-2006 05:07 PM
Which manifold? Breathers? gavinpierce Hotrodding Basics 4 02-16-2006 11:10 PM
Oil breathers and pcv valves scheetz93 Engine 6 06-01-2005 01:49 AM
