PCV help for supercharged sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2007, 05:13 PM
New Member
I am just about done building a 383 sbc with weiand 177 supercharger. I am running a Holley carb that was recommended for this setup. My problem is the PCV routing. I have vintage valve covers with moon breaters on both sides. A buddy suggested I drill and tap a hole in the fuel pump block off plate and run the hose to the hose fitting at the base of the carb with a PCV valve in line. Has anyone else set one up this way and does anyone have an opinion on this??? I realy don't want holes in the valve covers if possible.
Thanks,
Toolmansson
Old 01-29-2007, 05:50 PM
Wiki Edits: 31
get breathers that have vac line fittings on them, tie them togther with vac line, and T them to manifold vac, that should work ok. if you have breathers, you don't need a PCV.
Old 01-29-2007, 05:53 PM
F-BIRD'88's Avatar
Yada Yada Yada
As long as the hose does not get flooded with oil, it could work.
Old 01-29-2007, 06:07 PM
T-bucket23's Avatar
Wiki Edits: 26
Lose one of the breathers and install a PCV.
Vaccumn and PCV plumbing problem on SBC shockers69 Engine 4 06-25-2006 05:11 PM
SBC with no PCV pcoghlan Engine 18 05-25-2006 08:29 AM
Need help with PCV hose on my sbc 350 Bakdok Engine 1 08-21-2005 03:48 AM
Pcv - Does My Sbc Really Need One? HJCHEVY400 Engine 5 04-13-2004 05:44 PM
PCV Valve - SBC - 50's style valve cover spudone Engine 4 10-03-2003 08:22 PM
