PCV placement on New GM Goodwrench using vintage equipment - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 01:33 AM
I own a GM Goodwrench 350 motor using an Edelbrock intake with an oil filler tube and breather type oil filler cap, Edelbrock carb, original valve covers and air cleaner from a 1963 Impala. The motor is already in my car.My question is how do I run my pcv valve? I do not want to drill into my valve covers.
Can I run a pcv valve threaded into my oil filler tube and run that into my carb? Will this provide enough ventilation without causing engine problems? Or do I have to do something else to help it breathe. Thanks for any advice or help is greatly appreciated
Old 04-27-2011, 06:13 AM
delawarebill's Avatar
vac connection
the edel carbs have a large fitting on the center front and one in the back.. i use the front for the valve cover and the rear fr the trans.. looking at the front of carb the right small connection is for the dizzy and blank off the left one...
Old 04-27-2011, 01:13 PM
fast68's Avatar
likes chevy trucks & boobies
but he wants to run 1963 covers and those dont have pcv holes in them
and the block doesnt have road draft tube
so hmmm
im not sure what he can do then
if i were him and wanted to retain 60s covers but have pcv then id go for a set of 1968 1969 1970 covers
Old 04-27-2011, 01:24 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Look at what this guy did. http://forums.corvetteforum.com/c1-a...pcv-valve.html .
Cole
Anyone have a GM Goodwrench 350? 64_ss Engine 29 09-10-2009 01:51 PM
GM Goodwrench LM1 nootkabear Engine 14 11-08-2007 09:49 AM
Goodwrench 350 w/ TBI BadHabitSS Engine 17 07-27-2007 11:37 AM
cam 4 new goodwrench 350 Timothy Trankina Engine 14 05-03-2005 07:58 AM
GM Goodwrench 350 alex Engine 2 12-19-2004 08:08 AM
