pcv plumbing - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2009, 11:05 PM
pcv plumbing
Is it Ok to use the same input into the manifold as I am usingfor the power brake take off i.e. using a T piece or will I have to plumb each separately into the manifold? I am using a pcv installed directly into the crankcase hole next to the dizzy? I have early Corvette valve covers and prefer not to have to drill these.
Old 10-14-2009, 11:26 PM
life is a temporary assignment
I have seen it work before.. Give it a try, you will know if it does are not..
Old 10-15-2009, 01:02 AM
SSedan64's Avatar
I've seen the Trans modulator and Brake booster combined but, not the PCV. May drop the vacuum too low for booster.
Old 10-15-2009, 07:40 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
Do a search on this board and use the words "pcv corvette"...You may find something in those past posts regarding both options for the pcv and vacuum line locations.
Old 10-15-2009, 07:44 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I have never seen a OE application use the same fitting for the brake booster and another accessory needing vacuum. I think it is to reduce the chance of having a vacuum line failure and it affecting the brakes.
I am far from having seen everything out there, so there are likely exceptions.
Old 10-15-2009, 08:41 AM
dawg's Avatar
NAVY VETERAN
I have teed the PCV and brake booster for years and never had an issue.
just make sure your booster check valve is working (mounted right on the booster where the hose connects to.)
Old 10-15-2009, 09:38 PM
Thanks
Thanks guys for your quick response. IAs soon as i posted i saw the other threads and they gave me a good idea of the way forward. I need to sort out the PCV asap as there is oil blowing out by the dizzy and I want to be able to run the engine in without problems. I may put some other valve covers on the motor. Also found some excellent help with my hydraulic clutch issue. When i get back from work in november I will be sorting some things out.
Old 10-16-2009, 08:29 PM
renfroe453's Avatar
I have the same issue with my BBC. My PCV was plumbing into the carb spacer plate, but I just added a nitrous spacer plate and remove my 1" spacer. Now there is only one port on the carb available for a 3/8 vacuum hose and the booster vacuum is connected there.
Based on what you are saying, it should be ok to tee the PCV and the booster lines together?
I do have a vacuum canister installed which reserves plenty of vacuum for the power brakes.
PCV question.. Jsup Engine 2 06-17-2009 02:25 PM
the most efficient PCV valve setup ImRoyaltyInMyChevy Engine 5 04-26-2008 02:52 PM
Need Help/Advice with Ford 390 PCV!! texastomeh Engine 7 02-11-2008 02:27 PM
PCV and Brake booster plumbing strokey Engine 4 07-25-2007 08:31 PM
Vaccumn and PCV plumbing problem on SBC shockers69 Engine 4 06-25-2006 05:11 PM
