http://cgi.ebay.com/ebaymotors/ws/eB...T#ht_918wt_939 With the one side routed to the vacuum line at the base of the carb? |
Let's Not Forget The Baffle In The Valve Cover
Of course you are right, I just assumed his valve covers would have them already since about all factory ones do and most after market do also. Still that was a good point because had he used a cover without a baffle it would have caused some real problems and more than just a little smoke! |
PCV valves are good. They do not cause any power loss, on a street engine.
They suck the combustion byproducts out of your engine, and burn them. That means it is possible to get a slight but minor gas mileage increase from running one. These byproducts if not removed, will make your oil get diluted with unburned gasoline, and water sooner. Without a PCV valve, you will have to change your oil more often, or it will be dirtier when you do. They make the engine crankcase operate at a slight vacuum, and this reduces the tendency for oil to leak out. And finally, the blowby gasses formed by the engine are really pretty bad, as far as polluting the air goes. |
Wow guys, thanks for all the input! I am going to stay with my pcv valve set up. My first post shows the current set up, which has a pcv valve in the aluminum valve cover and the hose running to a manifold vacuum source from the carb. I guess it shows, "Sometimes your hotrod buddies don't always know what they are talking about. "
Glad we could help . BTW .Silicone heater hoses
I just looked back at your original post and thought you might want to know that there are silicone heater hoses available that are much more heat and oil resistant. Also they are a nice blue in keeping with the color theme. LOL We had gone exclusively to the silicone heater hose on the mine equipment due to the exposure to heat and oil . It is more expensive but a lot cheaper than an engine .
If one of your buddies told you that an alternative, as you indicated earlier, was just to use a breather cap on the valve cover or filler tube then he certainly can not be trusted. That would be just about as bad as no ventilation at all! Well maybe not that bad but for sure the oil would become very dirty and contaminated in short order with just that cap and no vent tube, the vent tube was by far more important than the breather cap as far as venting the crankcase and without it very little venting would occur other than to prevent pressure from building up. In fact just using the breather cap would allow slight pressure to build up possibly causing oil leaks and almost certainly causing an oily mess under the hood. |
Older Is Better ? ?
It never ceases to amaze me the number of people who think that the technology of the 60's is preferable to modern engine technology . I actually know a guy who took a perfectly good 350 out of his new pickup in the early 80's to replace it with a stock 327 that he had built . Check the performance numbers on the modern engine compared to the old muscle cars that we thought were so "hot" . GM and others don't spend millions annually on engineering to produce lower performance and lower reliability . I remember my '75 Nova SS had only a 12 mo 12,000 mile warranty . Now GM has 60 mo. 100,000 mi. That alone has to tell you something . So the short and sweet is , stick with the latest technology despite what your "hot rod" buddies try to tell you .
don't use silicone hose for vacuum line.. it isn't strong enough, and will collapse under the vacuum.
I made that mistake once.. replaced all my vac. lines with this cool silicone hose kit from the parts store.. quickly found out I had no power brakes because the hose collapsed under the vacuum.. only thing I use that silicone hose for now is my washer fluid.. |
| Recent General Rodding Tech posts with photos |
| PCV Valve Selection for a Healey | Healey64 | Engine | 9 | 08-13-2010 09:39 AM |
| PCV question.. | Jsup | Engine | 2 | 06-17-2009 02:25 PM |
| PCV Question | HotRodMan | Engine | 1 | 12-22-2005 10:43 PM |
| PCV question, just wondering... | ChevApache59 | Engine | 13 | 12-22-2005 05:48 PM |
| PCV question?? | low77ride | Engine | 12 | 10-16-2003 06:19 PM |
