PCV routing question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2011, 12:44 PM
I should change my user name to 'Rookie'. Another question on my 283. Can anyone advise or direct me to a good source of info, preferably with pictures, as to the correct or ideal routing & connections of lines/hoses for the PCV system on a SBC? I would really like to tap into the old road draft tube on the rear of the block, so, any ideas on that would be great. Thanks in advance.
Old 05-05-2011, 01:07 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Here's some ideas.
Rich
http://www.jalopyjournal.com/forum/s...d.php?t=151629
Old 05-05-2011, 01:20 PM
Not easy to find anymore, this is what you need.
http://www.classicchevy.com/chevy-pc...1955-1962.html
Bogie
Old 05-11-2011, 01:06 AM
PCV adapter (above) screws into hole where draft tube was. PCV valve screws into carb base (pipe thread). Hose connects them. Be sure your oil filler cap is the filter-type.
SBC Belt Routing Camaro2 Engine 1 11-08-2009 07:38 PM
PVC&breather routing yragat Engine 12 01-30-2007 07:02 AM
routing of coolant dubie Engine 2 06-30-2004 09:17 AM
Water Routing The Vandal Engine 1 04-07-2003 06:55 PM
EZ-Wiring routing question horvath Electrical 5 03-03-2003 04:54 PM
