PCV Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2007, 07:40 PM
PCV Valve
Hi
I have a 1980 Trans Am 4.9 Turbo. I want to change the PCV valve but it will not come out. It is on top of the intake. I tried tugging on it, it is loose in the grommet but will not come out. Any help would be appreciated......Miller
Old 05-22-2007, 07:59 PM
Buick Hybrid Guy.
Most have had the engine changed well before the PCV go's bad
The rubber has gotten hard over the years and won't give up the PCV valve
with out some serious KY Jelly. Lol...
Soak it with that PB Blaster or WD 40 several times and let it try to make
that rubber plyable again. Keep working it till it comes out. When putting the
new one in use lots of grease and be carefull not to push too hard and drop
the rubber down in the intake.
It'll come out.. she's just stubborn!
~Scott
Old 05-23-2007, 08:45 AM
PCV valve
Thanks a lot Scott. I will give it a try..........Miller
DO I NEED A PCV VALVE? IHAVECHEVYPARTS Engine 17 02-03-2012 02:46 PM
PCV Valve? RedskinFAN21 Engine 2 03-28-2006 10:47 PM
Suggestions on valve cover pcv valve baffle please! 67 Deuce 4 Me Engine 4 04-04-2005 05:45 PM
pcv valve A/G WILLYS Engine 1 10-13-2004 08:59 PM
PCV valve info question... Juicer Engine 3 11-06-2003 02:54 PM
