Sounds as if you have honed the cylinder with a diy spring -loaded unit. Were the bores checked for roundness before you honed. If the bore was out of round before you honed then the only way to get a concentric bore back is for a machine shop to do it.
Standard bore or rebored.If you dont have the telescoping bore gauges then you should try to get someone from the machine shop to come out and measure your cylinder diameter using their dial gauges, if the engine is still in the car. ????
