keiser, we aren't arguing, we're having a discussion.
Intense, a pcv valve is a calibrated, variable vacuum leak with integrated backfire protection which also seals the crankcase off from the intake under boost on forced induction motors. how is that for a description of the PCV valve? from one of the first classes i took years ago, "the PCV system is an emissions component, its job is to vent crankcase vapors into the intake to be burned instead of venting them to the atmosphere" before the PCV valve, engines used road draft tubes which vented to the atmosphere. before the road draft tube, there was just a vent tube to the atmosphere. before the vent tube, engines were sealed to contain the blowby. yes, they leaked oil, and they didn't last very long. some engines don't have a PCV valve, they use a fixed orifice with a vent to the air inlet. some engines don't use a fixed orifice or a pcv valve, they use an oil/air separator thats routed to the air intake tract. these are modern engines. it may have not been complete, but again i gave no misinformation. here is a test you can do if you want to see just how well the pcv valve actually relieves crankcase pressure vs the vent tube. remove the crankcase vent hose at the valve cover and plug the valve cover and leave the pcv valve and its hose completely intact to the intake, pull the dip stick and hook a vacuum/pressure gage to the dip stick tube and put the gage where you can read it. now go drive the car. at idle and light throttle, you will see crankcase vacuum. on a good motor that has good seals and gaskets, you may even see up to full intake vacuum. you can expect to hear the motor whistle with the crankcase sealed like this, and it isn't good on the seals either. now, if you remove the pcv valve and plug the valve cover and leave the crankcase vent hose intact, you won't see crankcase vacuum. you also won't see crankcase pressure unless there is a flow problem with the vent side or if it has excessive blowby because of bad rings that overwhelms the vent side. you shouldn't see any notable crankcase vacuum with a properly working PCV system. the highest specs i can think of are on some Volvos, about 7 inches of water max IIRC. i believe they also use a restricted vent tube. to check if the PCV valve is flowing the proper amount, find the specs for your motor and see if it matches the RPM drop. if you'll post what you have, i may well have the specs here at home. eric32, if they are not removed, crankcase vapors can cause acids to be formed and breaks down the oil faster. it helps to make the vehicle cleaner because the crankcase vapors are burned in the engine instead of vented to the atmosphere. venting to the atmosphere can make up to around 20~25% of total vehicle emissions on vehicles without a cat. for cars with a cat, i've read total vehicle emissions can increase up to 60~80% if crankcase vapors are vented to the atmosphere instead of the motor. a wrong or defective PCV valve can pull too much from the crankcase causing excessive oil consumption. if you have aftermarket valve covers, they could have poorly designed baffles in them. if you bought them used, the for your honda friends, in my 30+ years of auto repair i've seen more PCV valve failures on hondas where the valve has came apart internally than all other vehicles put together. cut away of an average PCV valve, |
Good info Soul,
Honestly everyone here has some bits and pieces that are correct about the operation of a PCV valve and how it works, and there's also bits and pieces that are incorrect. I found a Perfect explanation in my ASE Certification Books but with no Digital Camera no way to post a picture of it here. So I went and searched the internet to find something everyone can use that Explains the Correct operation and purpose of a PCV System.
This is by far the most Detailed Explanation I've found, even more so then my Automotive Books and ASE Certification books. This information is provided by Toyota Motor Co. and Has Tons of Fully detailed Pictures and explains the operation to the T of a PCV valve and shows how it operates. Hope this helps everyone! http://www.autoshop101.com/forms/h63.pdf Being a hardcore Ford and Chevy guy I know its disappointing it was made by Toyota but hey, I have to give them credit for a nicely laid out piece of information. Also in some ways this information is better then the Explanation my Mercedes Benz books gave. |
No problem man, I hope everyone else gets a chance to look at this
Good link. I got an A I think. Common sense would lead you to conclude the valve should, again, should be halfway area of travel in cruise. My main concern right now is getting a slight vacuum on the crankcase at idle. I'm going to run down to the dealer and get an oem pcv and see if this corrects the situation with the Purolator brand pcv.
My engine has a wide operating range due to the stock stall limit right now. If I can pull some vacuum it will help with my slight rear main leak and get a "head start" on crankcase pressure. I hope to better ring seal. Don't get me wrong, the engine has 65k and is in great condition. Looking to squeeze more out of it. Looking for high 12's with stock shortblock including cam, converter, gears at almost 4k pounds. I'm getting closer, corrected et is 13.4-13.5. |
to get negative pressure at idle you need to restrict the inlet flow total cfm severely (dip stick and breather) and find a weaker rated spring pcv
and it will take awhile to pull enough air out of the crankase to have a negative pressure.... the main seal leak is because the crank is literally throwing the oil with force at the seal.... always glad to learn so do post your results... Last edited by red65mustang; 01-25-2010 at 01:56 PM. |
A stronger, not a weaker spring would help more at idle. With no volume, pcv closed, there would be no negative pressure. That would be working in the right direction, OR a larger orifice allowing more air to "leak" past while the pcv valve is up(against spring) and closed. Yes, if I don't have enough volume pulled out pcv valve to intake it could take a little bit of time. Never seen it first hand, but it can't be that long. Open an air compressor with a 3/8 hole and it decompresses quite quickly. at 14 psi which would be 1" Hg of mercury or vacuum. I'd be happy to have that. |
typical oriface opening is approx 1/4" diameter,,,there are some with close to 3/8" diameter,,,problem is the larger diameter has a bigger and heavier piston!!
to work at idle you need a very light piston so it will lift easier and/or a weak spring so there is less lift resistance on the steel piston with the available suction cfm which ain't alot at idle... the carb venturi/throttle blade larger total "oriface" area is a easier path for the air to flow with the available suction from the slow moving pistons... how long will it take to get to signifigant negative crank case pressure would be about like how long it takes to fill a 5 gallon bucket with only a 1/4 diameter water hose... they are cheap enough at the chain parts stores to buy several different ones and tear them apart to make your own "combo" with a piece of aluminum tubing to experiment with???? Last edited by red65mustang; 01-25-2010 at 05:09 PM. |
dang CRS!!!
forgot to post: the suction volume limiter "bottle neck" is usually the 3/8" hose nipple on the carb,,,that tube I.D. is only approx 1/4" actual.... so a bigger oriface hole won't help.... Last edited by red65mustang; 01-25-2010 at 05:14 PM. |
| master cylinder interchange | runn141 | Suspension - Brakes - Steering | 7 | 05-03-2009 05:15 AM |
| cam question, any truth to this? | 406 ss monte | Engine | 9 | 03-30-2008 11:28 AM |
| Suggestions on valve cover pcv valve baffle please! | 67 Deuce 4 Me | Engine | 4 | 04-04-2005 05:45 PM |
| pcv valve | A/G WILLYS | Engine | 1 | 10-13-2004 08:59 PM |
| PCV valve info question... | Juicer | Engine | 3 | 11-06-2003 02:54 PM |
