PCV Valve - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-11-2012, 06:23 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by LBL
I used moly rings when I rebuilt it . I may be a little shy of 30 minutes when I think about it , we may have only ran it for 10 or 15 minutes so I'll run it some more today and see whta it's doing .
Do the rest of the cam break in first, then if possible take it out on the road so you can decelerate against engine braking as described in the link in my previous post.
  #17 (permalink)
Old 06-11-2012, 06:37 AM
67Mustang Al.'s Avatar
Just reading through the threads to have such high crankcase pressure i was thinking of a ring issue ( rings compressing on the way down )and when cobalt 327 said the "rings may be upside down" i was thinking along the same line of thought. Probably the worst case scenario but oil forced out the dipstick hole takes a fair bit of crankcase compression.
Al.
  #18 (permalink)
Old 06-11-2012, 07:54 AM
LBL's Avatar
LBL LBL is offline
Running Down the Road
Last journal entry: Interior
Possible
I guess that's possible but I took a lot of time and trouble making sure that they were put in properly. Would a compression test confrim or eliminate this idea?
  #19 (permalink)
Old 06-11-2012, 03:27 PM
LBL's Avatar
LBL LBL is offline
I went out to run the engine some more and break in the cam and it is not reving up like it did when I first started it on Saturday. It seems like the extra crankcase pressure is preventing it from reving up. What now ?
  #20 (permalink)
Old 06-11-2012, 03:49 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are you positive the right amount of oil is in it, and you (or a helper) didn't accidentally fill it twice or something?
  #21 (permalink)
Old 06-11-2012, 05:13 PM
LBL's Avatar
LBL LBL is offline
I wish
I wish that was the case, I only bought enough oil for one fill and I just checked the dipstick and it's right on. If I had a faulty lifter on an exhaust valve, would that cause blowback into the crank ?
  #22 (permalink)
Old 06-11-2012, 07:53 PM
A leak down test will as previously suggested. Once you pressurize the cylinder with piston on TDC you will soon see if there is a ring to cylinder wall sealing issue as there will be a large leakdown. It will also prove your head gasket seal between cylinders . A compression test for a 351 should show between around 140 -160 psi for a standard engine.
  #23 (permalink)
Old 06-12-2012, 07:31 PM
LBL's Avatar
LBL LBL is offline
Problem
I don't have the equipment to do a leakdown test so I thought I would do a compression test. Remember this is probably only after a combined running time of 1/2 hr. Anyways the results are not very good. On the passenger side, all cylinders are between 135 and 145, I was happy with that. On the drivers side, they go like this starting at the front: 132, 110, 135, 105. Is it possible that I have 2 bad exhaust lifters ? What should I look at next, I'm thinking of pulling the valve cover on that side and manually turning the engine over to see if all the valves are moving. If that isn't the problem, I guess the next step is pull the head and then pop those 2 pistons out. I am just guessing at this so any advice would be greatly appreciated.
  #24 (permalink)
Old 06-12-2012, 07:44 PM
On the cylinders that are low if you squirt some oil down the plug hole then run the compression test again you can determine if the rings are the probelm or the head gasket or valve seat sealing issue.
On the cylinder with 105 psi add 2or 3 squirts of oil from a can. Screw in the comp tester and crank it over. If your rings are the issue you will see a higher compression on the gauge as the oil temporarily seals the rings. I f the reading on your compression gauge stays the same (105)then you know it is a problem above the rings which only leaves valves or head gasket or in the worst case, cracks.
Al.
  #25 (permalink)
Old 06-12-2012, 07:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would start by readjusting the valves of the low cylinders to be sure none of them were set too tight.
  #26 (permalink)
Old 06-12-2012, 08:44 PM
LBL's Avatar
LBL LBL is offline
Lifters
The lifters and rockers that I'm using have no adjustment on them, they're the ones that just tighten until they bottom out on the pedestals. I'm going out to the garage now to try adding some oil to the cylinders. Thanks for the help you guys, i appreciate it .
  #27 (permalink)
Old 06-12-2012, 09:01 PM
LBL's Avatar
LBL LBL is offline
Damn
I put a few squirts of oil in both the low cylinders and got readings of 150 in both cylinders. Not too sure what the hell happened but I guess I'm pulling her apart again ...Damn!
  #28 (permalink)
Old 06-13-2012, 06:04 AM
Its disappointing but s--t happens. I was in at the engine reco shop today and mentioned your problem. He said a guy had a similar problem and had inserted the second compression ring in upside down . Cylinder bore diameter to piston clearance and hone finish is important also. And ring end gap sitting on a piston in the bore unless you have gapless rings.
Here is some reading for you.
ID:	66029   Click image for larger version
ID:	66030   Click image for larger version
ID:	66031   Click image for larger version
ID:	66032   Click image for larger version
  #29 (permalink)
Old 06-13-2012, 06:08 AM
Plus the last three pages of the chapter.
ID:	66034   Click image for larger version
ID:	66035   Click image for larger version
  #30 (permalink)
Old 06-13-2012, 06:20 AM
LBL's Avatar
LBL LBL is offline
Thanks Al
Thanks for the reading, as much as I am disapointed, at least I know what the problem is and can move forward to fix it. This is my first engine rebuild and I was quite happy that I had no leaks, or knocks and it fired right up so as soon as I get those pistons out and fix the problem, I should have a good strong running engine. If it is just a couple of rings in upside down, am I okay flipping tham or should I use new rings on those pistons? Thanks again
351 windsor, ford
PCV Valve Miller Engine 2 05-23-2007 08:45 AM
PCV Valve? RedskinFAN21 Engine 2 03-28-2006 10:47 PM
Suggestions on valve cover pcv valve baffle please! 67 Deuce 4 Me Engine 4 04-04-2005 05:45 PM
pcv valve A/G WILLYS Engine 1 10-13-2004 08:59 PM
PCV Valve - SBC - 50's style valve cover spudone Engine 4 10-03-2003 08:22 PM
