PCV Valve?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2012, 12:37 PM
PCV Valve??
I have a 62 comet, which we had the engine overhauled on.
I was told we needed a pcv valve... though from my research the pcv valve wasn't introduced til 63....
So do I need to put in a pcv valve? or is it just breathers?
Old 12-05-2012, 12:55 PM
The PCV valve was introduced on some engines in 1962, and on all vehicles starting in 1963. All your engine may need is a road draft tube to draw pressurized combustion air from the crankcase. All engines have a certain amount of ring blow-by which pressurizes the crankcase and forces oil vapors out of the breathers. Even too much exhaust back-pressure can cause oil vapors to be forced out of the breathers and can saturate the firewall with oil.
Old 12-05-2012, 01:02 PM
hcompton's Avatar
Old & Furious
not unless you want one or live in CA. just use some breathers.
Now pcv valve is supposed to help in performance a little by keeping the crank case vented correctly.
Old 12-05-2012, 01:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Even if the car didn't originally come w/a PCV system, a properly working system helps a lot more than it hurts. More here (there are a lot of threads on this if you want to do a search): Edlebrock Valve Cover Breathers???
Good luck.
Old 12-05-2012, 03:12 PM
Here is a good link to PCV Valve Operation, pages 3-5 in particular.
http://www.autoshop101.com/forms/h63.pdf
PCV Valve bergie Hotrodding Basics 45 01-25-2010 08:19 PM
PCV valve redneckhotrods Hotrodding Basics 1 04-11-2007 09:48 AM
Suggestions on valve cover pcv valve baffle please! 67 Deuce 4 Me Engine 4 04-04-2005 06:45 PM
pcv valve bigford556 Engine 9 11-22-2004 04:16 PM
PCV Valve - SBC - 50's style valve cover spudone Engine 4 10-03-2003 09:22 PM
