pcv valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2004, 08:20 PM
A/G WILLYS's Avatar
pcv valve
Howdy! I am putting a brand new small block in my 53 chevy with an offenhauser manifold with a filler tube I got some calcustom finned valve covers with no holes and i would like to keep them that way, I am using an edelbrock carb, I was wondering if i put an oil filler tube from a corvette with a pcv valve in it and hook it to the back of the carb would this be enough venitlation for the valve? any help would be appreciated.
Old 10-13-2004, 08:59 PM
DoubleVision's Avatar
as long as your connecting to the correct vacuum signal it`ll work fine, however, you mentioned vent, where is the vent? for it to work there must be fresh air ventalation for the pcv system, the vent needs to have a breather on it also.
