PCV Valve, do I really need to run one? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-27-2013, 10:30 PM
vinniekq2's Avatar
have you considered circle track valve covers?
just an example
These Allstar Performance steel valve covers feature reinforced rails for improved gasket sealing and are constructed from durable steel. They have two 1 1/2 in. baffled breather tubes on one and a plain top with no holes on the other. The valve covers come in your choice of finishes, so you can choose what's best for your engine compartment.
  #17 (permalink)
Old 02-27-2013, 11:11 PM
I had an issue with warping and getting a good seal with my old steel covers. thats why I went with the aluminimum ones.
  #18 (permalink)
Old 02-27-2013, 11:22 PM
vinniekq2's Avatar
HAVE YOU CONSIDERED CIRCLE TRACK COVERS,rofllll? they are extra vented. they also offer plumbing into the exhaust system
  #19 (permalink)
Old 02-27-2013, 11:36 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Those baffles are not for a pcv and wont work in the respect of keeping oil out of the vacuum line! They are for installing extra breathers!
You need a baffle that insulates the grommet and wont let liquid oil get close to the vacuum draw but lets fumes get to the PCV like a bottom vented box between the rockers low enough to be out of the oil cast off but high enough to be off the head surface! with those low profile covers it would be hard! They sure are "PURDY" though You may have to hook up a catch can like mentioned earlier!
Jester
  #20 (permalink)
Old 03-02-2013, 06:57 PM
I also ordered some pcv specific baffled grommets just in case. I'm also putting together an oil catch can setup. That should help me see just how much oil is actually getting sucked into the intake and burnt onto my pistons.
Why does my motor run poorly with the PCV? nat Engine 6 03-12-2007 08:27 PM
Suggestions on valve cover pcv valve baffle please! 67 Deuce 4 Me Engine 4 04-04-2005 05:45 PM
what to do with pcv valve?? mikeweyman Engine 7 03-08-2004 08:36 PM
PCV Valve - SBC - 50's style valve cover spudone Engine 4 10-03-2003 08:22 PM
