PCV Valve setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2012, 10:02 PM
fastnloud's Avatar
PCV Valve setup
I have an 82 GMC Sierra with a built 350, on my valves covers one side has a breather cap, and the other side has a push in style oil fill cap.
My breather cap is starting to go bad and it letting some oil come up out of it, I would like to go ahead and switch it over to pcv valve. What all do I need to do this?
I found this pcv valve.
Chevrolet Performance PCV Valves 6487779 - SummitRacing.com
But, is there other parts I will need to get it all set up?
Thanks guys
Old 12-08-2012, 04:34 AM
PCV Valve setup
Any auto parts store has the PCV valve. You would need the rubber grommet the fits the valve cover hole and some 3/8 vacuum hose.
The Following User Says Thank You to cdminter59 For This Useful Post:
fastnloud (12-08-2012)
Old 12-08-2012, 06:38 AM
Greg T's Avatar
www.krusinklassics.net
You'll probably need to retune the carb also. If you adjusted your AF ratio to optimum with no PCV then you'll be leaning the hell out of it when you put that huge vac leak in called the PCV.
The Following User Says Thank You to Greg T For This Useful Post:
Old 12-08-2012, 11:25 AM
75gmck25's Avatar
The stock setup has a PCV valve in a grommet in the driver's side valve cover, and there is a large diameter (3/8"?) rubber line running over the the carburetor. This is where is is sucking crankcase vapor into the carb base and then into the cylinder. As someone else mentioned, adding this extra air source may make your carb go leaner.
On the passenger side you can use a vented cap in the valve cover or a rubber line running up to the air cleaner filter area (this is the stock arrangement). This is where ambient air is sucked into the crankcase, so you just need a relatively clean air path. The stock setup uses a rough mesh filter on the air cleaner fitting to prevent sucking in too much dirt.
Bruce
The Following User Says Thank You to 75gmck25 For This Useful Post:
Old 12-08-2012, 04:51 PM
fastnloud's Avatar
Bruce
Right now mine has a breather cap on the passenger side, and the push in oil cap on the driver side. Can I just put a PCV Valve in the passenger side, and leave the push in oil cap on the driver side?
Thanks everyone for the help.
Old 12-08-2012, 05:22 PM
RWENUTS's Avatar
No. You need the pcv on one cover and a breather on the other cover.
The Following User Says Thank You to RWENUTS For This Useful Post:
Old 12-08-2012, 06:36 PM
fastnloud's Avatar
Alright thanks, so just use the breather as my oil fill cap?
Old 12-08-2012, 07:14 PM
RWENUTS's Avatar
Maybe.
Put the pcv on the cover that has a baffle under the hole. Use the other for your breather and oil fill spot.
Old 12-08-2012, 07:32 PM
fastnloud's Avatar
Maybe.
Alright, thanks for the help
PCV Setup in Turbocharged Engine trifivefan Engine 6 05-01-2011 10:26 PM
PCV setup SBC. Caballerokid Engine 13 03-06-2011 03:32 PM
on older engine--should convert to PCV valve setup? yragat Engine 10 08-31-2010 07:43 PM
the most efficient PCV valve setup ImRoyaltyInMyChevy Engine 5 04-26-2008 02:52 PM
PCV setup Nalehed Engine 7 07-11-2007 09:50 PM
