PCV valve, smoke out exhaust
So I've had the 355 for a while, got most of the details figured out; but i have a problem.
when i rev the engine above 3000 rpm or so, i get smoke from burned oil. I have had someone confirm it as well. Just had the heads redone, intake manifold is on right.
I have an edelbrock 600 cfm carb with the pcv valve on the drivers side, and a breather on the other. I just now realized that it doesn't make sense. Should i only have a pvc valve so that air doesn't get sucked through the breather, through the engine, and into the carb???
Its i really build 355, 7000rpm redline says the cam, mechanical lifters, 11.5:1 CR, dual exahust.
I only get the oil smoke at high rpm's, and the spark plugs verify it. Is there a change it would be the piston rings??? i go through a quart of oil every 200 miles or so, and the inside of the intake manifold is dark colored. And its a manual tranny, so no vacuum lines there. The only vacuum lines i have used a power brakes and pcv valve. All the intake manifold ports are plugged, and the unused carb ports are capped.
Ideas?? Should i just cap one of the valve cover holes???
Thanks, Josh
